Can't save custom image settings
Custom Image settings are not saved on my K-r. It is up to date with firmware Version 1.11.
Has anyone else experienced this problem?
When I adjust custom image settings and change the values of parameters such as Sharpness or Contrast, the settings are retained as long as I don't turn the camera off. But once I turn it off then turn it back on and go into Custom Image Settings, the parameter values are back at default settings.
I've verified that menu 4 > Memory > "Custom Image" is check-marked which retains custom image settings when the camera is turned off.
I've reset the camera to factory settings but still can't save custom image settings.
I don't have this problem with my K-5 and K2000 cameras.
Since, it's the weekend, I can't talk to a real person at Pentax tech support until Monday.
