I think, that your setup will not work. In wireless (master/slave) mode, you cannot set 2nd curtain with pentax flashes...your master/slave will flash always on 1st curtain - if I remeber correctly.
There are flashes with built in trigger to ignore preflash. I have one yongnuo 560 and it works...But if I mixed it with pentax flash booth as wireless slave and control them from on camera (540fgz as master), the result is that only yongnuo is visible in exposure...The pentax slave fires, but not on the right time
Metz flashes ca do wireless and 2nd curtain, but I don't have them
The working solution I found with my setup was described above. And I think it gives me a pretty good results. Manual flashes for atmosphere (especially in large rooms) and on camera pttl for fill.
