02-17-2012, 09:59 PM   #1
Kx settings with flash
Does it matter where my camera settings(flash mode) are when using an external ttl flash(Bower SFD 926P)? I don't find any information specific to that in the Kx manual. Also, do I have to keep my shutter speed faster than 1/180 for ttl to work? Thanks to all.
02-17-2012, 10:58 PM   #2
THe K-x doesn't support TTL (just P-TTL), so you'll have to set your flash to auto mode and adjust settings on the camera accordingly. Use 1/180s (the flash sync speed) and then whatever aperture will give you correct exposure.
02-18-2012, 02:53 AM   #3
sterretje's Avatar
According to Bower SFD926P Digital Shoe Mount Flash for Pentax/Samsung SLR SFD926P, it supports P-TTL
On current Pentax dSLRs, the X-sync speed is 1/180s. If the flash supports HSS, you can go faster, else you're limited to 1/180sec or slower.
Are you experiencing any (specific) problems? In which modes?
I usually use Av and occasionally M mode when using flash. Aperture determines the reach, shutter speed the amount of available light that will be 'recorded' in the image. And stay away from auto ISO; I don't like it in the best of times but I hate it when using flash.
Note: I don't have the K-x, so answers are 'generic'.
camera, kx, pentax help, photography, ttl
Flash Settings Using M Series Lenses On The K X shutterpuppy Pentax DSLR Discussion 9 01-07-2011 12:01 PM
Flash usage settings? jrsavs Troubleshooting and Beginner Help 3 10-20-2009 08:41 AM
What settings should I use for my flash? somethinchill Troubleshooting and Beginner Help 2 07-08-2009 05:59 PM
What settings to use on flash when diffused Okami Pentax DSLR Discussion 3 02-22-2008 11:20 AM
Flash settings Stratman Pentax DSLR Discussion 8 11-05-2007 06:21 PM
All times are GMT -7. The time now is 10:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
