02-19-2012, 08:22 AM   #1
Help! 50-135 2.8 AF Adjustment
I recently purchased a 50-135mm 2.8, and I've been testing the focus accuracy on my K-7. It seems to focus reasonably accurately at 135mm, but at 50mm, it quite severely back-focuses. Is there any way to fix this?
Here are two sample shots. I added the SD card, just to make sure I knew where the camera was focusing. These are both shot on a tripod, no changes except the focal length of the lens.
135mm
55mm
As you can see, at 135mm, the camera focuses accurately enough, with the front edge of the card nice and sharp. At 55mm, the focus is way off, with the card blurry. Looks like the focus is around the 5, way behind what I wanted to focus on.
How do I fix this?
02-19-2012, 12:49 PM   #2
Has anyone experienced this? is this something fixable using the K-7 AF adjust?
02-19-2012, 12:57 PM   #3
Anvh's Avatar
Take away the SD card and focus on the black line under it, i know you added the SD card to make it lear where it focu but actually it doesn't make it clear...
Anyway if you still have the same problem adjust the lens on the 135mm value and see how it reacts on 50mm.
It is btw not that strange that the lens focus differently
02-19-2012, 01:09 PM   #4
QuoteOriginally posted by Anvh Quote
The focus was just as bad without the sd card, but I wasn't sure if the AF system was focusing on the black line or not. WIth the SD card, I'm pretty sure I know its attempting to focus on the card.
I've see others report on different focus adjustments at different focal lengths. But what can I do about it? It doesn't really need any adjustment at 135mm (maybe +1,) but at 50mm it is way way off.
02-19-2012, 04:02 PM   #5
Marc Sabatella's Avatar
You don't. The card is a very larege object with very little contrast. The camera won't focus o the card itslef but perhaps on the edge between the card and paper - but then, you don't know which edge it will choose. Ipor if it will ignore the card entirely and find something on the paper to focus. By covering up the easy target that the chart was designed to give, you just made it impossible to know where the camera would try to focus.
It's easier to mess up a focus test than to conduct one properly.
02-19-2012, 04:21 PM   #6
Anvh's Avatar
What Marc says, whit the first it actually seem to focus on the front edge of the card but in the second on the edge in the back.
02-19-2012, 05:17 PM   #7
Yep, I'm starting to realize that.
I'm using the chart from here: Jeffrey Friedl's Blog , but the lens has to be pretty far away, so i have no idea what the camera is focusing on.
What would be the best way to test this?
02-24-2012, 08:36 PM   #8
I have the exact same issue with the same lens I just received today. I posted over at dpreview. Hopefully someone can shed some light on the situation.
02-24-2012, 08:40 PM   #9
Anvh's Avatar
QuoteOriginally posted by arnie0674 Quote
Take away the sd card, that's all and do it in day light
PS. I just read the instruction on the site you post, you do know all these things are explained there...
02-24-2012, 09:36 PM   #10
Get one of these and you'll never have any more doubts:
Fixing Front and Back Focus - Introduction - PentaxForums.com
02-24-2012, 10:30 PM   #11
Not useful as the lens correctly focuses at 135mm
02-24-2012, 11:37 PM   #12
Anvh's Avatar
QuoteOriginally posted by kiwizz Quote
Send it to Pentax, they are the ones that can fix it.
02-25-2012, 04:53 AM   #13
Looks like I will have to do just that. Haven't even had the lens a day and it needs to be sent off for repairs. Not much going for Pentax quality control these days.
02-25-2012, 05:43 AM   #14
Exchange it. I had to when I bought mine a few years ago. 2nd one is fine.
02-25-2012, 06:24 AM   #15
Pentax Japan have told me they do not replace lenses. Sending it back to B&H would cost more.
135mm, 55mm, camera, card, focus, pentax help
For Sale - Sold: Super-Takumar 35mm F2.0, 50mm F1.4, 135mm F3.5, 300mm F4 MightyMike Sold Items 195 10-14-2012 07:04 PM
Move from 18-135 to 16-50 + 50-135 DA* Lenses brosen Pentax SLR Lens Discussion 34 11-08-2011 05:11 PM
Takumar 135 2.5 vs Super Tak 135 3.5, both bayonet mount, which is better? chongmic Pentax SLR Lens Discussion 7 04-09-2011 11:55 PM
All times are GMT -7. The time now is 12:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
