03-01-2012, 02:41 PM   #1
Deimos's Avatar
"Halo" around objects in photos after B&W PP
Hi All,
I have fairly recently started processing from RAW using LR 3.5 and sometimes Silver Efex/Color Efex
In a few of the B&W shots I processed first in LR then did B&W conversion and some tweaks in Nik Silver Efex Pro
I am pretty sure the haloing (lighter edges around subjects) comes from something Ive done in Silver Efex
Can anyone help me identify what might be causing this and any steps to avoid it?
Thanks!
These two show it pretty well:
03-01-2012, 02:50 PM   #2
baro-nite's Avatar
It's the same sort of glow you see in tonemapped (HDR) images. I don't know what goes on in Silver Efex Pro, but lots of the output I see looks pretty much like tonemapping, even if they may call it something else. Try less of whatever contrast adjustments you made and see if you can reduce the glow to the point it isn't distracting. Or just do a straight B&W conversion and then do the contrast adjustment in Photoshop or equivalent software. With a clear sky and smooth edges as you have here, the masking should be straightforward.
03-01-2012, 03:09 PM   #3
riff's Avatar
I believe that any software that boosts micro contrast will halo if pushed far enough.
I sometimes see haloing in the real world with only my eyes.
03-01-2012, 03:57 PM   #4
Na Horuk's Avatar
In lightroom the 'clarity' slider can cause something like that. What does the original coloured photo look like?
03-01-2012, 04:37 PM   #5
Deimos's Avatar
Thanks for the help guys
QuoteOriginally posted by baro-nite Quote
Someone in another thread asked me if I used HDR for these, I am thinking it is whatever I am doing in silver efex, could have been the contrast adjustment..Ill try to look out for this next time
The orig coloured photos after LR processing look fine, no halo/glow from there I would have taken the photo into Silver Efex after, used a preset and made a few tweaks.
The clarity value is 55-65 ish on almost all my photos, but I have only seen halos in B&W. I am pretty new to RAW PP in LR, is this "a lot" of clarity?
03-01-2012, 04:49 PM   #6
Deimos's Avatar
I just took one of the LR processed colour files into SIlver Efex and went through a few of the presets, the halos indeed appeared after contrast was boosted
At least I know where this is coming from now
Thanks!
03-06-2012, 05:54 PM   #7
Lowell Goudge's Avatar
Just an odd hunch here but what about color blooming or longitudinal CA?
I would bet o. Longitudinal CA where you have a light green fringe in the behind the plane of focus, and this is showing up as lighter than the sky when converting to B&W. Try reducing the green level in a mask layer before the B&W conversion
03-06-2012, 09:44 PM   #8
Deimos's Avatar
Interesting I will try
03-06-2012, 09:57 PM   #9
twitch's Avatar
I find the "soft contrast" slider in Silver Efex creates halo's like these, check wheather you've pushed it to either extreme...
03-07-2012, 06:48 AM   #10
If you want to fix them after processing, here is a great tutorial.
Sharpening Halos And How To Hide Them - Tutorials
Tim
efex, flickr, lr, pentax help, silver
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Point And Shoot Contest #13 "Ordinary Objects" Duh_Vinci Pentax Compact Cameras 18 12-09-2008 07:22 PM
June "Pentax Challenge" voting thread - Ordinary Objects betsypdx Mini-Challenges, Games, and Photo Stories 10 07-09-2007 06:24 PM
June "Pentax Challenge" - Ordinary Objects betsypdx Mini-Challenges, Games, and Photo Stories 11 06-23-2007 03:18 PM
All times are GMT -7. The time now is 08:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
