03-10-2012, 06:24 PM   #1
Aperture issue with SMC Pentax-FA 80-320mm F4.5-5.6
Hello,
I bought a SMC Pentax-FA 80-320mm F4.5-5.6 for a bargain price. However I can not set the aperture in any mode. I usually shoot in Av mode but it is impossible to set the aperture manually. The aperture ring on the lens is set to "A".
This is what I get on my top display.
Is this normal or is the lens defective ?
Thanks
PENTAX K20D  Photo
03-10-2012, 07:04 PM   #2
boriscleto's Avatar
Have you tried cleaning the contacts on the lens?
03-10-2012, 07:14 PM   #3
I did and it did not work
03-15-2012, 12:52 PM   #4
It's a normal fault, the internal circuit fails.
Mine was the second that I had seen, Having enquired prior to the purchase of the repair cost, I got the price down to a good deal and went for it.
Put it directly into the repair house and collected 3 days later for about 30-35, 5 years ago (if I remember correctly) still behaving perfectly. Asahiphoto of Brentford West London carried out the work and quoted that this is common for this lens.
Hope this helps
Alan
04-23-2012, 08:44 AM   #5
Iksobarg's Avatar
had to check the one I just got in the mail today!
seriously? "defectious?"
Anyway, I found mine works, but for how long?
So I kinda don't get it for the one that doesn't work...
that means the camera is not able to auto control the Fstops?
and/or in manual Fmode the camera doesn't register the manually set Fstop?
04-23-2012, 08:49 AM   #6
LaurenOE's Avatar
I've got that lens too, and I have taken it apart to fix the middle element as that comes unglued - at least in mine. It's a great lens and is one of the easier ones I have worked on. It's good to know that there is an electrical issue cause, if my copy begins to fail in setting the f-stop.
Even with my repairs, I don't use it much. I have one of the gray ones. It seems the silver ones outnumber the gray ones by a wide margin.
04-23-2012, 09:01 AM   #7
unixrevolution's Avatar
QuoteOriginally posted by Iksobarg Quote
Not all of our users here speak English as a first language.
I believe he has it set in A, where a Pentax DSLR should set the aperture automatically, and it will not.
04-23-2012, 09:21 AM   #8
I did set the camera in Av (Aperture Priority) and I put the lens aperture ring on "A". The camera would not let me select the aperture value as illustrated in the picture above.
04-25-2012, 01:45 AM   #9
Hi BNBPhoto,
I would think that there are probably electrical contacts in the aperture ring mechanism, and like any contacts, they can become oxidized or corroded when not used for a length of time, or there might be some debris causing a loss of contact. I'd suggest that you depress the A lock button on the aperture ring and rotate the ring back and forth a good number of times to see if this might provide a better chance of a good contact.
Scott
aperture, aperture issue, f4.5-5.6, lens, mode, pentax help, pentax-fa, smc, smc pentax-fa 80-320mm
Pentax SMC FA 80-320mm or Tamron 70-300mm Macro Travis Pentax SLR Lens Discussion 4 02-01-2011 08:50 AM
For Sale - Sold: SMC-FA 80-320mm w/filter and more (US) NicK10D Sold Items 5 07-10-2010 08:15 AM
SMC Pentax-FA 80-320mm lens Green_Manelishi Pentax SLR Lens Discussion 7 06-05-2009 08:47 AM
For Sale - Sold: Pentax SMC FA 80-320mm xs400 Sold Items 6 05-10-2009 05:26 PM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, part of our network of photo forums!
