Originally posted by tim mcdonough
Thanks for all the input, I think I'm starting to understand. I just want to make sure if I shoot with the brand new 35mm lens will the photo more or less look the same as if I used the older 50mm lens?
It will look similar to the old 50mm lens shot on film. it will not look similar to the 50 on your digital camera. this is why I said ignore any and all crop factor arguments. they are not relevant if all you shoot is an apsc camera. lens sizes don't change on formats, field of view or angle of view of the lens differs on different formats. As an example I shoot 50 mm on apsc, 35mm film and 645 medium format film
If i am trying to compare how they look and use a 35mm camera as my base then angle of view acts as follows
on 645 my 50 mm performs like a 30mm wide angle on 35mm film (or FF digital)
on 35mm film my 50 mm performs as a standard 50 mm lens
on apsc my 50mm performs as a short tele (or like a 75mm on 35mm film)
in all 3 cases i am using a 50 mm lens but they all provide different FOV based on the size of the sensor (or film frame)
Normal lenses have always varied by format. mmost people think of a 50mm as normal on a 35mm camera, actually normal for 35mm is actually 43mm, but 50's were cheaper and easier to build and not different enough to be an issue
on apsc (at least the 1.5 crop of sony/pentax/nikon not the 1.6 canon crop) a 28 mm is pretty close to a perfect normal, but anywhere from 28-35 is accepted as a normal lens. mostly you will se 35 since they are common and translate [pretty closely to the defacto standard of 50mm on FF(or 35mm)
645 a normal lens was a 75 which is pretty much a 45mm lens in terms of a FF camera.
confused now i bet.
so back to my original statement ignore any and all crap factor arguments you don't shoot on ff or film so it's irrelebvant. use the lenses and you'll get a good idea of what they are best at.
on apsc
Ultrawide is 8-16mm for the most part
Wide is 16-24mm
normal is 28-35
short tele/portrait is 50-85
tele is 100+
