View Poll Results: Do you use a blower to clean the internals of your interchangeable lens camera?
Yes 6886.08%
No 1113.92%
Voters: 79. You may not vote on this poll
03-25-2012, 05:28 PM   #16
patrick9's Avatar
Rocket blower when dust start to show in photo's
03-26-2012, 03:56 PM   #17
amber waters's Avatar
Rocket Blower here...love it!
03-26-2012, 07:39 PM   #18
Anvh's Avatar
Wow am i the only one with bad experience with them?
I only blow the dust onto other parts inside the mirrorbox, did i use it wrongly?
03-26-2012, 09:08 PM   #19
I use a mid-size broom. Lol just a Giottos rocket blower. and not all internals, just the mirror box and the sensor occasionally.
03-27-2012, 12:28 PM   #20
TER-OR's Avatar
Only when absolutely necessary.
03-27-2012, 01:08 PM   #21
lammie200's Avatar
How were you using one?
QuoteOriginally posted by Anvh Quote
I only use one when I find dust on pics, but I also needed to use one when installing focusing screens. I take the blower out of a plastic bag and do about 15-20 puffs before it goes near the camera. Then I turn the camera upside down and blow about 15 more times. Seems to work fine. I also have the dust shake turned on on startup. I know that people get very scientific about explaining why or why not it is good to use one. I just visualize a small box with one side open and talcum powder lining the box. If you turn the box upside down and use a blower on it, I am sure that you will see the talcum powder spewing out the opening. Might be a question for the Mythbusters, though there is the potential for them to damage the neighborhood trying.
03-27-2012, 01:41 PM   #22
Anvh's Avatar
I don't hold the camera upside down but i point the lens opening down though
But with the K10D the viewfinder was pretty clean but after the first time i used it the viewfinder was pretty dirty...
And it was a blower designed for cleaning SLR so no tacum inside.
03-27-2012, 02:13 PM   #23
lammie200's Avatar
Sounds to me...
Sounds to me like you need to wash your hands first.
03-27-2012, 02:33 PM   #24
Anvh's Avatar
I solved it differently like i already wrote down
03-27-2012, 02:46 PM   #25
Den
Den's Avatar
Only to get rid of the leaves on my driveway
I have a low pressure, oiless, hospital grade, HEPA filtered small compressor I used to use in the darkroom. I would use that if I needed a blower.
03-28-2012, 02:13 AM   #26
I started with using a blower and it worked for a while but then I got dust on top of VF focus screen so I just use Pentax sensor cleaning stick for normal dust and "Visible Dust Plus" for the one welded on something I had. Only had to wet clean 1 time in a year and it worked really well..
The best money I ever spent was buying a Visible dust "lighted sensor loupe". It is pricey but well worth it for the time it saves me. Funny how well things work when I can see the dust and then verify I removed it. No more taking pictures of blue sky or white sheet of paper. No more retesting. Just one step. A simple/quick/effective routine as it should be.
People should do whatever works for them using the method of their choice/expense!
03-28-2012, 03:56 AM   #27
I use a blower with a filter, works for me.
03-28-2012, 04:07 AM   #28
TOUGEFC's Avatar
I use the air from my lungs
03-28-2012, 04:32 AM   #29
Docrwm's Avatar
QuoteOriginally posted by TOUGEFC Quote
Hot, moist air inside the camera - no thanks.
03-28-2012, 04:55 AM   #30
TOUGEFC's Avatar
And spit too
pentax help
Rocket Blower - Have I been... DaveHolmes Troubleshooting and Beginner Help 17 06-16-2011 06:30 PM
Wanted - Acquired: Giottos Rocket blower SlickYamaha Sold Items 2 06-14-2011 06:47 PM
Image sensor cleaning risk using blower bulb bwDraco Troubleshooting and Beginner Help 5 11-10-2010 07:46 PM
Check blower for insects Transit Pentax DSLR Discussion 7 10-17-2010 06:17 PM
Bulb blower Russell-Evans Pentax Camera and Field Accessories 5 09-12-2010 08:38 AM
All times are GMT -7. The time now is 03:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
