03-28-2012, 09:06 PM   #1
Loose aperture ring on Super Tak 35mm f2
Hello all..I just got what I thought was a very nice 35mm f2 Super Takumar. The aperture control ring moves fine from left to right with sold indent movement but it also moves up and down within its chanel. I would say the ring has vertical movement of between 1/16-1/8 inch, making it feel sloppy. This can't be normal?...or is it. This is my fiirst Pentax legacy lens so I'm not sure if this is within specs for this lens.
I would love to keep the lens if this is normal/ to be expected but it was an eBay purchase so if it is going to be returned, I am up against the clock. The ring works fine and the aperture opens and closes smooth and snappy...BUT is this an indication of a bigger problem...a past repair? Please advise. Thanks
03-29-2012, 07:30 AM   #2
You say the ring moves "up and down" - do you mean along the axis of the lens, towards the front & back? If so it should be an easy fix. On the SuperTaks the aperture ring is held in position by the ring just in front, that has the index mark and DOF scale. That ring is held in place with 3 small screws around the middle. If these screws have loosened, that ring could slip forward, allowing the focus ring too much room.
If this is the issue, get a set of fine screwdrivers and find one that fits the screws. Work over a clean surface so that if a screw falls out you can find it. You may need to loosen slightly, then slide the "index" ring back to hold the aperture ring more tightly. Turn the lens to the infinity stop, make sure the index mark lines up with infinity on the focus ring, and tighten the 3 screws.
aperture, f2, lens, movement, moves, pentax help
Super tak 35mm f2 vs. Vivitar 35mm f1.9 Pepe Guitarra Troubleshooting and Beginner Help 7 08-26-2011 07:23 PM
Loose distance scale ring on Super Tak 105/2.8 Swift1 Pentax SLR Lens Discussion 2 10-17-2010 10:39 AM
Super Tak 35mm f/2 - Mana from Heaven woof Pentax Film SLR Discussion 9 08-26-2010 09:17 AM
All times are GMT -7. The time now is 07:42 AM. | See also: NikonForums.com, part of our network of photo forums!
