Originally posted by L33tGreg Why macro without tripod?
Commonly encountered reasons I mainly do handheld macro:
- Too much structure to plant a tripod, branches, rocks, uneven ground, mud, water. Also, shooting vertically along walls (say, to get under spiders) doesn't have enough clearance to plant a tripod.
- Impossible angles. I'm not carrying a selection of tripods everywhere, and even the small mini ones are often too tall for a shot.
- Not enough time. Bugs are often flighty and I'd rather get the shot handheld, than get a tripod set up in time to watch it fly away.
- Related to the last point, tripod legs are notorious for bumping foliage and scaring the subject.
I'm referring mainly to ~1:1, maybe 1.5:1 magnification, I find it's manageable handheld. Much beyond that, say 2:1 onwards to 5:1, I do prefer a tripod, but I don't as often need that much magnification. Once I finally get into focus stacking, I bet that will be a different story, but for single shot macro it holds up.
Edit: And Lowell nails it. SR is next to useless, unless you're shooting in strong wind where you get some horizontal movement. Better to turn it off and use a flash, or if it's bright enough, just a fast shutter. Breathing is very important, too. Focus with your shoulders, be aware of your breathing, and shoot on the exhale. Just breathing normally probably alters the camera to subject distance by 1cm with every breath, if you're not careful.
