Originally posted by aaronkeogh I really love the using the K-5 with the 18-55 kit lens, but the 18-55 lens has one design flaw in my opinion that is really annoying!! I like to shoot at 18mm/ 27mm (35mm Equivalent) most of the time but what I've noticed is that the lens easily changes focal length with any minor pressure to the front element. When you zoom from 18mm to 55mm the front element goes out at 18mm - in at 35mm and out at 55mm. Wouldn't it have been better if they designed it so that 18mm was as far back as it could be and 55mm was as far out as it could be rather than oscillating out, in and out? Maybe this is common with all 18-55 lenses, even from Nikon and Canon etc...
There is s simple reason for having the front element in its forward position at the shortest focal length: the lens hood won't vignette then, wheras you might get dark corners, if the front lens would be inwards at 18mm. I never tried, how close the standard hood is in its form, but at least from the point of basic logic, this makes sense.
By the way, many shorter fl zoom lenses behave the same way, for instance the really good and big FA 28-70/2.8.
Ben
