04-08-2012, 08:50 AM   #1
k20d auto bracketing
when using the auto bracketing on a k20d the little line on the ev bar (on the underexposure side) on the lcd panel blinks no matter what exposure i'm using, is it suppose to do that?
04-08-2012, 11:42 AM   #2
Anvh's Avatar
If it blinks then the exposure is out of range of the EV bar.
That can be good or a bad thing depending on your purpose, if it would be your normal shot then it's not good but if it's under or overexposure shot then it might be correct depending on the EV spacing you have chosen.
04-09-2012, 09:50 AM   #3
slr
called Pentax, what this means is, in custom settings i have it set for - 0 + for auto bracketing, if i had it set for + 0 - then the line on the + side would blink, if i had it set for 0 - + or 0 + - then the middle line would blink, this all means that the line that blinks is what the first exposure is going to be in auto bracketing. thanks for your input.
04-10-2012, 08:36 AM   #4
Anvh's Avatar
Not entirely, watch the line and you will see it jumps around the EV.
So with 0 - + it should go from the centre then go left and then go right so it indicates the exposure it's taken.
auto, k20d, pentax help
Auto Bracketing in M mode Northern Soul Troubleshooting and Beginner Help 6 09-20-2011 03:09 AM
645D auto exposure bracketing? gurtch Pentax Medium Format 2 12-26-2010 03:40 PM
Auto Aperture-Bracketing Reportage Photographic Technique 9 11-13-2010 09:39 PM
HDRI-Auto Bracketing ollio Pentax DSLR Discussion 13 05-31-2008 08:58 AM
auto bracketing jnoelle Photographic Technique 19 05-09-2008 10:23 AM
All times are GMT -7. The time now is 12:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
