04-11-2012, 08:26 PM   #1
GeoJerry's Avatar
Auto-bracketing Issue
I have a K-7 and shoot in RAW. When I shoot auto-bracket using 3 shots, I have no problems. When I use 5 shots, I find that the last one is often delayed. It's not a long shutter speed - it can happen on a bright day. Is this some kind of memory buffer problem, a delay in getting that fifth picture into memory? If so, is it fixable?
04-11-2012, 08:32 PM   #2
Are you using the expanded dynamic range setting? That might slow things down.
04-11-2012, 08:55 PM   #3
GeoJerry's Avatar
I have it set on 100-400.
04-11-2012, 09:16 PM   #4
MSL
MSL's Avatar
Are you shooting JPG, RAW or JPG+RAW?
An easy way to test if it is a memory problem is to start with the smallest file type - low quality 6meg jpeg (or the equivalent on a K-7 as I have a K-5). If the problem disappears, keep bumping up the file size and see when it first appears. That would give a sense of whether it is a buffer or memory card problem. At least I think this should help...
04-11-2012, 09:37 PM   #5
GeoJerry's Avatar
Shooting RAW only.
Good idea, will try a few low quality shots and see if the problem goes away. Do you notice this problem with your K-5? I'm thinking of moving up soon.
04-11-2012, 09:39 PM   #6
MSL
MSL's Avatar
It isn't often that I shoot bursts of 5 when bracketing, but I have shot rapid sequences of more than 5 images without problem. This may have been when I was using JPG rather than RAW, but even now, I don't think I have problems with bursts, although there can be a long lag at the end of a burst as the buffer is cleared.
04-11-2012, 09:43 PM   #7
GeoJerry's Avatar
I've noticed a similar issue with bursts. I will check this out as well with the same test. I'd be surprised though if it turns out you can't burst more than 4 images when using RAW. Seems like that would be a major design flaw. Or it could be a bad SD card, I need to check that as well using a different card.
04-12-2012, 03:14 PM   #8
Wheatfield's Avatar
Are lens corrections on?
04-12-2012, 03:16 PM   #9
GeoJerry's Avatar
Yes I always leave that on by default.
04-14-2012, 12:10 AM   #10
Wheatfield's Avatar
QuoteOriginally posted by GeoJerry Quote
Turn them off and see what happens.
04-14-2012, 01:47 PM   #11
GeoJerry's Avatar
Bingo. I switched off lens correction (and chromatic aberration to boot), and the problem disappeared, both in bracketing mode and in burst mode. Thanks very much! Will turn those off permanently.
04-14-2012, 06:49 PM   #12
MSL
MSL's Avatar
Well spotted Wheatfield. I've never tried turning them on, but as soon as I saw your question I figured you were on to the problem, as I recall that those corrections do slow down the camera quite a bit.
04-14-2012, 07:27 PM   #13
GeoJerry's Avatar
Have either of you noted that the lens correction (or chromatic aberration) makes much difference? Can PP just get rid of the problem, if there is one, anyway?
04-14-2012, 07:30 PM   #14
GeoJerry's Avatar
By the way, I've noted a lot of Canadians on these pages. I wonder if Pentax is more popular up there, and/or better marketed? Seems like almost a secret brand down here in the states. You won't see them in many camera stores, and not in any newspaper ads either.
04-14-2012, 08:03 PM   #15
MSL
MSL's Avatar
I only bought mine in January, so I can't give you much history. What I was told by my dealer is that the Pentax reps/distributors were making a big push into Canada late last year and early this year. Whether that is true or not, it was clear that the rebate/discounted pricing hit Canada well before it hit the US, and also seemed to end here sooner. At one stage the pricing got pretty aggressive with Henry's offering a K-5 with kit lens for $999.
I know there are a lot of Canadians on the forum, but it may also be that this is a friendly place to hang out, which is why we congregate here.
memory, pentax help, shots
k20d auto bracketing slr Troubleshooting and Beginner Help 3 04-10-2012 08:36 AM
Auto Bracketing in M mode Northern Soul Troubleshooting and Beginner Help 6 09-20-2011 03:09 AM
645D auto exposure bracketing? gurtch Pentax Medium Format 2 12-26-2010 03:40 PM
Auto Aperture-Bracketing Reportage Photographic Technique 9 11-13-2010 09:39 PM
auto bracketing jnoelle Photographic Technique 19 05-09-2008 10:23 AM
All times are GMT -7. The time now is 07:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
