I would definitely ask the seller for a partial credit or return it for a refund if there was no mention of the mark.
Originally posted by Wheatfield ...
Dust on a lens isn't going to affect it's picture taking ability unless there is a ridiculous amount accumulated
i respectfully disagree with this statement. When shooting sunrises, sunsets, or strong oblique light, sometimes even the slightest bit of dust particles can light up and make little spots on the image. I've seen this far too often to disregard and whenever i know i'll be shooting into the sun, i check my front element thoroughly and blow off dust. Similarly, cleaning scratches can also light up in strong light and cause flares. For all other shooting, such light dust is probably unnoticed in the image, so i agree with you on that. I always use a hood as well.
Originally posted by Wheatfield ... in which case a soft brush or compressed air/canned gas is a better way to remove it.
Also, a well washed old t-shirt is one of the best fabrics for cleaning lens glass if smudges have to be removed.
i wouldn't dare touch a T-shirt to any lens I care about. The fibers are rough enough to cause micro scratches, but more importantly, the cotton fibers are not able to lift and hold dust so you drag the dust around on the lens. if there was a piece of wood dust or sand, you could be scratching the coatings by cleaning.
I prefer to blow off large particles with the rocket, then very lightly brush the element with a lens pen brush. And only then if there are water spots, fingerprints, grease, etc, that remain, i use the lens pen tip. In the absence of a lens pen, i would use a microfiber cloth.
Make sure your cloth was not washed using fabric softener or it can leave a residue that is hard to remove.
Let's be careful out there!
