Originally posted by karlito139 Hi,
I just add the same probleme with my RZ18. I solved it by turning it on while pressing the blue button with a triangle in a rectangle (the one for viewing the pictures you've taken). The camera will turn on in the viewing picture mode. After that the camera works great.
BTW : When I did this manipulation the SD was out of the camera.
Hi! I just have a quick question because I have the same problem as you had right now. I hope you take time to reply and help out a fellow Pentax user. When you said your RZ18 keeps shutting down immediately after turning it on, did the problem happen regardless of whether or not there was memory card in the camera? I tried your method with and without the memory card placed inside but to no avail.
Right now, I'm thinking of opening the camera myself because the service center quoted me a price so high I could buy a new camera albeit with a bit lower specifications. I have my precision tools (small screw drivers, Phillips, etc.) but the problem is that it seems the screws Pentax used are so soft that my precision tools are just carving right through them.
I don't know what to do anymore. I am not rich and I saved really hard for that camera only for it to be wrecked for no apparent reason at all. I didn't drop it, I didn't overuse it. I used it with as much care as I could.
Sorry for the rant. I hope to receive a reply. Thank you.
