hi guys, i recently found an old Tokina 35-105mm manual zoom lens and took some great pics with it with my K-x. As my first manual I thought they could only be used wide open BUT it turns out that the aperature ring on the lens is broken and stuck on fully open.
There is a small tab inside the lens which I can turn and this closes the aperature and I can then turn the ring to open to full but I cannot use the ring to close it again (should there be two internal tabs, one to close and one to open the aperature?)
Anyway, I'm a bit gutted because I was so happy to have found this lens and it is still VERY sharp (much sharper than my kit lens), but obviously its usefulness is limited now it can only be used wide open. I bought an extension tube the other day specifically for use with this lens before I discovered this fault.
What do you guys think? Should I keep this, try to open and fix it myself (
) or try and send it for repairs (I'm not sure how much this would cost)
Thanks!
