04-19-2012, 12:41 PM   #1
jaywes's Avatar
Future Lens Problems?
I recently purchased a Pentax-F 70-210mm f/ 4-5.6 lens of eBay. It was a risky move but I was able to get it fairly cheap so it was worth the risk. My problem is there is a slight discoloration inside the front element/glass. See the photos below.
I have taken a good amount of photos with this lens and it doesn't seem to have any affect on the IQ. See the attached photo I captured with this lens on my K-r. [F/5.6 210mm ISO200 1/1000 sec]
Will this cause problems in the future? Should I send it for repair? What am I looking into for repair cost? Any advice would be helpful. Thanks
04-19-2012, 12:46 PM   #2
Can you tell if the discoloration is on the outside or inside of the glass?
04-19-2012, 12:50 PM   #3
eddie1960's Avatar
it looks like a mar in the coating, in most cases it will have no effect, it may cause flare with some oblique light hitting it. A good hood will prevent most of that since it is at the edge. Not worth a repair (or maybe not even possible)
OTOH it could be from liquid getting inside and drying like that leaving residue. it is then possible that it may have activated fungal growth just keep it dry and it should be ok though
04-19-2012, 12:52 PM   #4
jaywes's Avatar
QuoteOriginally posted by luftfluss Quote
Seems to be on the inside of the front glass.
04-19-2012, 12:54 PM   #5
jaywes's Avatar
QuoteOriginally posted by eddie1960 Quote
OK. I use a rubber hood and have not had any IQ issues. Hopefully it stays that way. I will keep an eye on it. [I keep all my photo gear protected and dry. ]
04-19-2012, 12:59 PM   #6
eddie1960's Avatar
QuoteOriginally posted by jaywes Quote
then you should be good
If you got a good price and it doesn't seem to affect the iq then really there is nothing to fret over, just watch for signs of fungus (which can be cleaned)
I saw a blog once that shot buy a lens with a shattered front element. the pictures were surprisingly good
found it
How Dust and Damage on Lenses Affect Image Quality
04-19-2012, 01:50 PM   #7
RioRico's Avatar
There's a game we can play with (cheap) lenses: HOW MUCH PUNISHMENT CAN THIS F*CKER TAKE? Game play usually involves using a geologist's hammer on a lens objective. Give it a few whacks, take a few shots, whack it a few more times, etc. You'd be amazed how horribly the glass must be damaged before IQ starts to decline. Slight discolorations of the front are trivial. Now, gunk or trauma to the REAR element can be more serious. But don't worry about the front. No twisted knickers needed. Have fun!
EDIT: I just noticed that this is my post #9900. Top of the world, Ma!
04-19-2012, 02:38 PM   #8
Docrwm's Avatar
Thanks for that information, because I have two that I got in a package deal that are F series zooms that have pristine rear elements but the fronts are a mess. My, few, shots so far area all fine. I'm wondering if they're worth keeping and I think I'll put more effort into evaluating them because of what you said.
04-19-2012, 02:57 PM   #9
RioRico's Avatar
QuoteOriginally posted by Docrwm Quote
Scratches and gouges on the front can be bothersome but are easily dealt with. Small ones can be touched-up with black magic marker or india ink, which keep light from bouncing off crack edges. Bigger ones can take some of that instant-windshield-repair gunk that dries with a refractive index close to glass. But splotches and scraped coatings just usually don't matter. I have a couple mistreated lenses that prove this.
Hmmm, I should do a reversed-lens trauma test. Flip a lens for close use, then whack (or at least discolor) the REAR element, which when reversed is now the objective. But I really don't like whacking lenses. That's almost as bad as squashing kittens.
04-19-2012, 03:02 PM   #10
Could be oil from the lubricating grease, if it is left in a hot place the grease breaks down and
the oil in it spreads around.
Once bought a 35-70 F lens and it looked like it was full of water droplets inside but
turned out to be the Silicone oil, cleaned it up and the lens was fine.
The oil will give that rainbow like color if lit from the side.
If it was cheap it could be a good time to practice ...
04-19-2012, 03:02 PM   #11
Docrwm's Avatar
One is worse than the other, but the AF works and its intact otherwise, and effectively has 0 resale value so experimenting with it might be educational. Thanks.
04-20-2012, 12:04 AM   #12
sterretje's Avatar
Somebody already had fun: LensRentals.com - Front Element Scratches
04-20-2012, 05:13 AM   #13
RioRico's Avatar
QuoteOriginally posted by sterretje Quote
That's only a vicarious thrill. Too remote; not tactile enough. Down-home do-it-yourself funfunfun is more rewarding. More adrenaline. More sweat. Ooh ooh. Where's that hammer? [/me goes bestial]
04-20-2012, 06:21 AM   #14
Philoslothical's Avatar
More fun with damaged lenses can be found here. It's really remarkable just how abused the front element can be without having a noticeable effect in most shots.
future, future lens, lens, pentax help, photos, repair
Perfect Future Travel Lens Set? Loren E Pentax SLR Lens Discussion 20 01-02-2011 06:44 PM
The future Perfect Lens Kit? Advice from more experienced Pentaxians please Loren E Pentax SLR Lens Discussion 18 10-29-2010 12:45 PM
Fantasy lens: 200-400mm compact F8 apo WR for high ISO future cameras p contor Pentax SLR Lens Discussion 2 05-29-2010 12:06 AM
hope all future lens come with SDM xbadx Pentax News and Rumors 12 08-29-2007 11:00 PM
My future lens kit mediaslinky Pentax SLR Lens Discussion 12 04-22-2007 07:00 PM
All times are GMT -7. The time now is 10:04 PM. | See also: NikonForums.com, part of our network of photo forums!
