04-25-2012, 09:05 PM   #1
tweet25's Avatar
dots of dirt - help plz
Hi
I have a K-r - i get spots on my photos - same spots no matter what lens. I have attached 2 photos, they seem different depending on shutter speed, sometimes they look like dots and other times like chunks of dirt. I have used the auto Dust removal feature and this does not help. Do I have to send my camera away to have it cleaned? Is there something I can do? (I have tried those little hand blowers- it didn't work) thank you to anybody in advance who can give me some advice. J
PENTAX K-r  Photo
PENTAX K-r  Photo
04-25-2012, 11:10 PM   #2
calsan's Avatar
Easy to fix, you need the little gummy stick that pentax make. It's mentioned in your manual:
Pentax O-ICK1 Image Sensor Cleaning Kit
Pentax O-ICK1 Image Sensor Cleaning Kit 39357
Not cheap, but cheaper than ruining your camera with some other method or sending it off for cleaning. Can be reused many many times, so should last you several cameras.
04-26-2012, 06:14 AM   #3
Wheatfield's Avatar
This makes people crazy, but I use canned gas (Dust-Off, specifically) for blowing dust off of sensors.
04-26-2012, 09:50 AM   #4
TER-OR's Avatar
Worth trying a blower first, see if it's easily removed. Always try the easiest, less tricky method first. If that doesn't work, then you may need the cleaner kit.
04-26-2012, 10:12 AM - 1 Like   #5
paulh's Avatar
Try the Rocket Blower first, then the above-mentioned cleaning kit if the sensor is still dirty. Meanwhile, you can edit those spots out using your photo editing software. Use the Clone Brush, Clone Tool, or Touch Up tool, etc. Easy fix if there aren't too many spots to remove.
04-26-2012, 10:14 AM   #6
tweet25's Avatar
QuoteOriginally posted by TER-OR Quote
I have tried the little hand blower, it did't work. Can you use the 'air in a can'? I thought you could do more harm than good with those? Is that true?
thank you calsan I am going to order the kit, just to have handy in case I end up needing it. I have tried 'you tubing' how to use the kit, and I can't find a good video, I hope it comes with good intructions.
04-26-2012, 10:35 AM   #7
tweet25's Avatar
OMG shipping is 52.00 guess i have to try and find it somewhere else....
04-28-2012, 07:50 AM - 1 Like   #8
Peter Budd's Avatar
Do no use a aerosol air blower. It will most lokey ruin your sensor. very fine drops of liquid will come out of these aerosol air blowers
04-28-2012, 09:26 AM   #9
Wheatfield's Avatar
QuoteOriginally posted by Peter Budd Quote
Urban myth and not true. Like I said, it makes people crazy when I say I use canned gas, an it's because people buy into this sort of tripe.
04-28-2012, 07:43 PM   #10
tweet25's Avatar
i don't know, even if something bad only happens once every 10 thousand times, you'd have to know me, to know it would happen to me ... lol... I can't afford for it to happen, huummmm mind you if it did happen I would be forced to upgrade to a K-5 ....... bring on the air !!!!! :evil:
07-29-2012, 08:02 PM   #11
The problem is when someone uses it for more than just a quick 'hit'. Using "dust off" makes the nozzle cold very quickly and then condensation forms and joins the gas stream. At that point you have a problem. I have used it in just a very few quick puffs of less than a second and had good results. If your spots are more stubborn than that, find some other way.
07-29-2012, 09:02 PM   #12
SpecialK's Avatar
A "big" rocket blower, not a "little" hand blower. You need to move a lot of air :-)
07-29-2012, 09:42 PM   #13
tweet25's Avatar
thank you - I will try that, i am 1 step away from shipping it to pentax to get it cleaned. It is driving me nuts
07-30-2012, 09:01 AM   #14
reeftool's Avatar
After 5+ years, my K10D is constantly in need of cleaning. I will occasionally use canned air too. BTW, the couple of spots on the posted shots are nothing. My vacation shots, much of which was spent on beaches and very windy, had around 20 or more. That sand seemed to get into everything. I cleaned all my gear with compressed air. The spot healing tool is my friend. The dust removal on the K5 is much better.
07-30-2012, 06:07 PM   #15
Marc Sabatella's Avatar
QuoteOriginally posted by tweet25 Quote
Have you read about how to do it? You do realize you need to lock the mirror up first, right? And do it in very strong light. If you can't see the dust on the sensor with your own eyes, you won't have a very good chance of blowing it off.
dirt, dots, pentax help, photos, spots
Need help buying tripod plz. capote Troubleshooting and Beginner Help 36 12-23-2011 09:48 PM
DA 12-24 -can i use Protection and plz filters spartan Pentax SLR Lens Discussion 3 07-05-2011 08:08 AM
Looking for specific type of lens, plz help Nass Pentax SLR Lens Discussion 11 06-18-2011 03:29 PM
contract help plz. boosted03gti Photographic Industry and Professionals 2 02-08-2011 07:34 AM
Some perspective on the K5 issues plz! ozlizard Pentax K-5 184 02-05-2011 01:05 AM
All times are GMT -7. The time now is 02:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
