05-03-2012, 03:53 AM   #16
Lowell Goudge's Avatar
QuoteOriginally posted by Nass Quote
Also, are you covering the eyepiece during the long exposure?
QuoteOriginally posted by twitch Quote
Now there's a thought.....
Won't be an issue unless the mirror does not cover 100% of the prism because the mirror is up . Usually the eyepiece impacts metering, but..... Maybe
05-07-2012, 09:05 AM   #17
v5planet's Avatar
I was about to post a similar question. I just purchased a B+W ND110 along with a few Singh-Ray GNDs the other day. Took them out for the first time yesterday, and noticed this strange banding artifact along one edge of the frame in several photos. I have been unable to reproduce it on my own, but it appeared in several photos where I used the 10-stop ND filter in conjunction with a GND.
(excuse the terrible exposure)
There's obviously some weird glare going on there in general, but the clean vertical band was quite confusing to me. It appeared even on some shorter exposures (<10s). I will have to experiment with covering the viewfinder, though, because I think in all the photos it appeared, the camera was angled slightly downward (off this cliff). Sun was below the horizon in front of me, but perhaps there was enough light coming from behind and above?
05-07-2012, 09:19 AM   #18
v5planet's Avatar
Quick follow up that will be of interest to the OP: not covering the viewfinder was exactly the problem I was having. Just ran out to the driveway and tried to reproduce my setup from yesterday:
DA15, 10-stop B+W, Singh-Ray GND
portrait orientation
facing direction of sunlight
camera angled downwards
The left image was taken without covering the viewfinder; the right image i just held my hand over it during the exposure. Striking difference.
Now I need to find my viewfinder cap, which I haven't seen in approximately 1000 years.
05-07-2012, 10:49 AM   #19
mikeSF's Avatar
im late to the party but shoot a good bit with my 9-stop ND and that is classic light leakage from the eyepiece. I've screwed up many an outing by forgetting my cover but i've learned a lesson.
Now, if only those little covers weren't so easy to lose. I'm down to my last one and painted it white to help spot it with a flashlight in the dark. I lost the last one on the beach at night.
05-07-2012, 10:57 AM   #20
Nass's Avatar
*stops hitting head against brick wall*
05-08-2012, 01:56 PM   #21
gordon_l34's Avatar
Hi,
What I have done is get one of those leads that allow you to hang your glasses around your neck, and attach one end to the camera strap and super glue the other end to the viewfinder cap. Use only Loctite brand super glue as it is the only one with any strength and longevity.
Regards.
05-08-2012, 04:17 PM   #22
twitch's Avatar
This has me wondering, I've never covered the eyepiece for my long exposure shots on either my K-x or K-5 and my photos don't seem to suffer these kind of issues.... or maybe they do and I haven't noticed.
05-08-2012, 04:21 PM   #23
mikeSF's Avatar
twitch, it mainly occurs when there is some light behind the camera and you have moved away from physically blocking the eyepiece, and most often with strong ND filters where the amount of light coming in the back is far greater than that coming though the lens.
05-08-2012, 04:22 PM   #24
mikeSF's Avatar
in some cases, it may have resulted in a slight loss of contrast.
05-08-2012, 04:25 PM   #25
mikeSF's Avatar
QuoteOriginally posted by gordon_l34 Quote
Hi,
Regards.
good tip, thanks! so far i have designated a tiny zipper pocket in my camera vest to hold the little bugger(in a small plastic SD card case). nevertheless, at times i need to utilize it, i always seem to be at the beach in 20mph winds.
05-08-2012, 04:57 PM   #26
twitch's Avatar
QuoteOriginally posted by mikeSF Quote
Mike, that describes just about every long exposure shot I take. Hmmm. I'll have to dig out the box the camera came in and see if I can find that little eye piece cover thing.
05-08-2012, 06:34 PM   #27
v5planet's Avatar
I don't know twitch. it would only happen for me when the camera was pointed downward. if I recall most of your long exposures hepoint slightly upwards. there may not be enough light coming from below to be a problem.
05-08-2012, 06:43 PM   #28
twitch's Avatar
QuoteOriginally posted by v5planet Quote
True, almost all are taken with bright sun behind camera, but the camera is pointing up. I'll experiment though and see if it makes any difference.
filter, issue, pentax help, picture
Strange grip and/or camera issue Nebulous Pentax K-5 & K-5 II 2 03-17-2012 05:28 PM
K5 - strange focus issue richardtugwell Pentax K-5 & K-5 II 16 09-20-2011 09:24 AM
For Sale - Sold: Pentax 16-45mm DA, 67mm UV filter, 58mm UV filter (Worldwide) treue_photo Sold Items 6 04-23-2011 01:28 AM
Strange EXIF orientation data issue? peterh337 Pentax DSLR Discussion 5 10-13-2010 12:38 AM
Vivitar 90mm f2.5 Macro - Strange Aperture Issue hangu Pentax SLR Lens Discussion 6 04-09-2010 05:56 PM
All times are GMT -7. The time now is 10:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
