Originally posted by Sage97 Thanks for the response guys.
Do you typically turn on the highlight and shadow correction? I was hoping to "park" these settings in one area if possible and adjust only when absolutely needed.
OK, I shoot perhaps a little differently than most, relying on JPEG for 99% of my shots and only shooting RAW if I a) really really need the shot, or b) am unsure of the best approach.
I use highlight and shadow detail for what they are, extensions to the contrast range, and use them to compensate for the lighting conditions at the time. If the scene is flat, and lighting is flat, I turn them off, to increase the contrast. DItto with the contrast settings, WB and to a lesser extent the saturation. I change them all the time as a function of lighting conditions,
My approach is to get as close as possible with JPEG, which usually is so close that while perhaps a tweak here or there is possible, it is not absolutely necessary. Even with RAW shots, using my editor (PSP X4 or Pentax Photo Lab), both of which can use the camera JPEG settings and apply them to the imported RAW image it gets the adjustment close without having to start from scratch.
Getting the settings right is a post processing time saver if nothing else, and if the JPEGs are close enough, an eliminator also.
