05-05-2012, 07:40 AM   #1
50mm 1.7 rear element yellowish haze
Got a Pentax M 50mm 1.7 from local flea market. Clean all the fungus on the front & rear element by following helpful instruction on this forum. Really helpful and thanks.
Anyone can help to get rid of these yellowish haze at the rear element, its in between 2 glass and I think it glued together?
Canon EOS 600D  Photo
05-05-2012, 08:43 AM   #2
Hi,
if this is an element of two lenses from the rear as it shown on a sheme on a link - than the haze is a lens separation. In such case, unfortunetely, there is nothing that could be done. I had similar issue with SMC 55/1.8 - it is a group of two lenses glued together.
http://kmp.bdimitrov.de/lenses/primes/_optics/50f1.7.gif
This haze most probably would not affect hte image quality.
Sorry for the bad news.
Yuriy
05-05-2012, 09:00 AM   #3
I have seen three examples of the 1.7 and all of these had blurred rear elements attributed to lens separation. it seems that this is an inherent weakness of the 1.7 lens. two of these lenses were given to me but were useless.
05-05-2012, 05:05 PM   #4
kcobain1992's Avatar
May I ask what did you use to clean the fungus, and if the haze is not actually on the lens surface?
05-05-2012, 06:10 PM   #5
QuoteOriginally posted by yurko_yr Quote
If, indeed, there is separation, the group elements can be re-cemented by a good tech, though it is probably not worth the trouble or expense. To be honest, I must echo kcobain1992...what did you use to remove the fungus. If the infestation was bad enough to etch the coatings (usually the case) removing the fungus will likely result in damage to the coatings or even the glass itself. I have seen two lenses in the last month where this was the case.
As for the M 50/1.7 being prone to rear element separation...that is a new one for me. I have been active here for several years and have never heard of such a thing. Fungus growing in the balsam cement, yes...separation, no.
BTW...to the OP...Welcome to the Pentax Forums!
(...has one way to deal with fungus...immediate removal to sealed plastic bag...thorough hand washing and cleaning of work area...deposit in trash or send back to seller...)
05-05-2012, 07:45 PM   #6
I use moniter cleaner which did quite a good job to the rest of the lens. The haze is in between the 2 glass lens so probably its the cement getting hazy. may b will try to seperate n re cement myself?
Yup best way to deal w fungus......back to seller. Unfortunately cant return.
Thanks for the warm wecome!
50mm, element, haze, pentax help
8 element vs 7 element 50mm f1.4 RMJ Troubleshooting and Beginner Help 8 09-19-2011 12:11 PM
Will Pentax M50/2 rear element group fit M50/1.7? altopiet Troubleshooting and Beginner Help 8 08-20-2011 09:22 AM
50MM Rear Element Seperation Sloglass Troubleshooting and Beginner Help 3 05-31-2011 02:52 AM
Push-on/slide-on rear element lens caps Edgar_in_Indy Pentax Camera and Field Accessories 12 04-16-2011 09:20 AM
Damaged rear lens element on F70-210, can the element be replaced? WendyB Pentax SLR Lens Discussion 13 01-05-2008 08:41 AM
All times are GMT -7. The time now is 07:34 AM. | See also: NikonForums.com, part of our network of photo forums!
