05-07-2012, 02:44 AM   #1
Capturing pictures with camera connected to PC
I am an amateur photographer with a Pentax K-5 camera.
I want to take pictures from my Windows 7 PC using the Pentax Digital Camera Utility.
I set the USB Connection to PTP on the camera and I'm connecting it with a USB cable to the PC and the PC recognizes it as a devise.
My problem it that I can't seem to be able to capture the images using the Utility program, and I'm not sure if I'm even going about this in the right way. The program has a lot of settings that I can change but no obvious "capture image" button??
Any suggestions about what I'm doing wrong?
05-07-2012, 02:52 AM   #2
Chaos_Realm's Avatar
The 645d is the only current dslr with tethering support by Pentax.
Having said that there is a program called pktether which does what you need. Just type that into google and it should be one of the top options
05-08-2012, 01:14 AM   #3
abmj's Avatar
Just to add to the previous post:
What you want to do is called "tethered" shooting and is a common feature in higher end, pro camears. Many studio pros shoot tethered most of the time. The Pentax software you are using is not a tethering application and will not do what you wish. Pentax does not specifically support tethering in any of its consumer DSLR cameras, only the medium format 645D. A third party company has a beta program that works in most cases. You might want to give it a try as mentioned above.
05-08-2012, 06:30 AM   #4
Stone G.'s Avatar
As said by Chaos_Realm, PK_Tether will do the job for you. With a Windows 7 machine you should be able to download and run the program right away (as it should have the required .NET installed already). You will find the download site here:
PK_Tether | Tethering and remote control software for Pentax DSLR cameras
I use it as well with my K200D as with my K-5 and it works fine (though not entirely without bugs). There are certain directions that must be followed; notably:
  • Turn of the top LCD display light
  • Do not use live view with PK_Tether
Further: If you search this forum for" pk_tether" you will find quite a lot of user experiences.
camera, pc, pentax, pentax help, photography, pictures, program, usb, utility
Nikkei: Ricoh-Pentax to release low cost Internet-connected ILC camera JPT Pentax News and Rumors 74 04-26-2012 02:55 AM
moving pictures from PC to camera shekh Digital Processing, Software, and Printing 4 11-09-2010 03:12 PM
When Connected to USB taking pictures cbaytan Pentax DSLR Discussion 2 09-25-2010 02:43 PM
Best lens for capturing new born baby pictures s_prasad22 Troubleshooting and Beginner Help 12 09-05-2010 01:48 PM
Misc Connected Isolation anotherrandomuser Photo Critique 14 03-03-2010 04:20 PM
All times are GMT -7. The time now is 01:30 PM. | See also: NikonForums.com, part of our network of photo forums!
