05-08-2012, 06:14 AM   #1
Kx AF/MF switch issue
I am thinking f buying a Kx for my 6 yr old, she is really great with a camera, just needs practice. I can get a used Kx for next to nothibg but the AF/MF swith is locked in MF but still AF lenses fubction with it as if in AF mode. I would like to get it repaired. Has anyone had this problm, and was it expensive to fix? I don't want to get a great deal on a used camera only to spend a mint fixing it.
05-08-2012, 07:24 AM   #2
jatrax's Avatar
Is she ever going to use manual focus? If not, then use it and get it fixed when/if the issue arises. k-x is perfect for a youngster due to the light weight but I think it will still get a few knocks about. I shudder to think what it would have looked like after a few weeks with either of my two kids at that age.
05-08-2012, 08:03 AM   #3
Hi dnd,
Here is a photo of AF/MF switch mechanism on a dead ist ds: i don't know if kx is similar.
https://www.box.com/s/14eb9eda270840c93ea0
The K mount ring can be removed by undoing the 5 screws with a jis driver.
Most of the switch mechanism is then exposed.
The switch pushes the AF drive in and out and when it is retracted, actuates the little gray microswitch.
You might be able to see the problem, it is fairly simple on the ist ds.
You could try to remove the ring in a dust free area and turn the body upside down and blow out the mirror area when finished.
Good luck, here (reposted link) is our 6 yo using the kit lens in AF.
https://www.box.com/s/c362d247a5d1dd92aa44
Actually the M4/3 might be better for a 6yo to handle, here is one he zoomed and composed with the Rikenon manual zoom on Sunday
https://www.box.com/s/86b89d6375e55657d5ec
af, af/mf, camera, kx, pentax help
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Switch is off, but everything still on. LightMeter Pentax Medium Format 2 09-16-2011 10:01 PM
AF/MF switch biloxisean Troubleshooting and Beginner Help 11 05-11-2011 06:44 PM
I can't switch on my K-x Camera limweeteck Pentax Camera and Field Accessories 10 08-06-2010 10:03 AM
Stiff On-Off Switch on K7 seachunk2 Pentax DSLR Discussion 4 06-27-2010 07:29 PM
All times are GMT -7. The time now is 12:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
