05-10-2012, 08:48 PM   #1
Corrupted image files
Shot a bunch of images with my new K5 with SD card that I didn't reformat after use in my K-X. Lightroom does import, but files don't show and import finishes with "unknown error". I can view the images in Iphoto, but it won't import them either. Suspect corrupted SD card though its always worked in K-Xs. Tried various file recovery software with no luck. Got 27mb (approx) pef files imported to mac with Image Capture, but unable to view them. I can only see them in the Finder.
Help! any ideas would be of great service. Don't want to shoot my son's grad pics again if I can help it.
Thanks!
05-10-2012, 09:34 PM   #2
hcc
hcc's Avatar
What kind of file recovery software did you use?
I had a corrupted card once. I was able to save some photographs by running Recuva (Recuva - Undelete, Unerase, File and Disk Recovery - Free Download) to recover files on the SD card. Recuva is a open access software.
Hope that the info may help.
05-10-2012, 11:05 PM   #3
sterretje's Avatar
I've only dealt with corrupted cards where the files were lost, not with corrupted images. Having said that, I don't give you much hope for the raw files. With a little luck you might be able to extract the embedded thumbnail.
PDCU4 has the option to extract the embedded thumbnail. exiftool should also be able to do it. At least you have something.
PS:
as you can preview the images, extracting should be possible.
05-11-2012, 10:34 PM   #4
mysticcowboy's Avatar
QuoteOriginally posted by sterretje Quote
PS:
Probably not. The preview is not the PEF file but the associated JPEG.
One outside possibility might be to put the card in the Kx and try importing via USB.
05-12-2012, 07:57 AM   #5
ramseybuckeye's Avatar
QuoteOriginally posted by mysticcowboy Quote
I would try that, but you will probably are only going to get the jpg preview. I got corrupted files once by not formatting a new card. I always format the card in camera after unloading pics, never had a problem except that one time with the new card.
05-12-2012, 11:53 AM   #6
sterretje's Avatar
You did not read the full post Or I was not clear but I referred earlier in the post to 'extract the embedded thumbnail'
card, files, image, images, import, pentax help, sd, view
Corrupted Files in Lightroom blockamon Pentax K-5 15 09-19-2012 11:41 PM
Corrupted raw files on SD card Pablom Digital Processing, Software, and Printing 6 03-03-2012 03:34 PM
Lots of corrupted files blockamon Pentax K-5 15 10-26-2011 10:49 PM
Weird Corrupted Files on Memory Card krp Troubleshooting and Beginner Help 10 08-02-2011 07:27 PM
Corrupted Pentax RAW Files wadedesk Pentax Camera and Field Accessories 3 07-09-2009 04:03 AM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
