05-11-2012, 03:25 PM   #1
Dewman's Avatar
10.2MP enough for 8x10?
....I'm going to keep asking 'em till I wear out my welcome.
My question is....with a digital camera than is rated at 10.2 MP, is it possible to print an acceptable 8x10 if you use the "full frame." This is, of course, assuming that the original shot is of reasonable quality, i.e., very little "noise," and needs little if any cropping? If not, what would be the biggest you think possible?
Maybe this sounds like a goofy question, but I don't know how else to ask it. I'm still thinking in terms of my "film camera" days, 'cause that's all I've got to draw upon....at the moment. But, hey....cut me some slack....I'm trying to get educated as fast as I can.
05-11-2012, 03:36 PM - 1 Like   #3
RioRico's Avatar
Think of it this way: What are the image dimensions (in pixels) of that 10.2mpx sensor? About 4200x2800? A common high-quality printer setting is 300 dpi (dots per inch). So you'd get 12.6" x 8.4" at super-photo-quality, that stands up to close inspection with a magnifier. But printed images are usually meant to be viewed from a distance at least the diagonal of the print. So a 24x16" print would look seamless when seen from about 30". Basic rule: Almost anything looks good if seen from far-enough away.
05-11-2012, 04:14 PM - 1 Like   #4
Dewman's Avatar
Youz guys are the greatest. I was indeed fortunate to find this site. I've learned so much in so little time....and I've just begun! Thanks fellas. I appreciate your patience and knowledge.
Dewman
05-11-2012, 05:57 PM   #5
Wheatfield's Avatar
FWIW, the biggest print I made from my K10 was 20x24, and it was superb. The interpolation subroutines in modern printers are excellent.
05-11-2012, 06:43 PM   #6
Brooke Meyer
Guest
QuoteOriginally posted by Dewman Quote
Yes. First 20x30 print I ever sold. K10 & Tamron 28-75. BC Ferry from Vancouver to Nanaimo .
PENTAX K10D  Photo
05-11-2012, 06:53 PM   #7
Nowhere Matt's Avatar
An 8 x 10 will cost less than $3 to have printed. Take a chance and see how you like it.
I have printed 6mp images at 20 x 30 and they are impressive.
05-11-2012, 10:06 PM   #8
Tom Woj's Avatar
As has been mentioned, printing hardware and editing software is getting so advanced these days that they can make anything look good from a quality stand point. 10mp is fine for an 8 x 10 - and as Matt put it, it's cheap enough to test loads of times over. I'd be more concerened about getting correct colour, shadow, and highlight detail than anything else - printing is a pain in the ass to get right, because they will never look exactly the same as they would on even the best calibrated monitors.
Bit off-topic, but you can always stitch multiple shots for larger prints. I've got a 160cm x 40cm panno up on my wall - printed from about...I think...5 or 6 shots stitched into a 10.8k by 2.7k image. Came out better than expected. Of course that only really works for landscapes or where nothing is moving. :P
05-11-2012, 11:18 PM   #9
RioRico's Avatar
BTW, aspect ratios can become an issue in printing digital pix. Our dSLRs shoot an aspect of ~3:2. An 8x10" print has 5:4 aspect. An image framed for the viewfinder must be finessed to fit on the blockier print: crop it, or distort it, or frame it deceptively. It's very tempting to compose an image that is just freaking PERFECT when you shoot it. It's much more prudent to leave space around the subject so the pic can be safely cropped. Just a suggestion...
05-19-2012, 10:55 AM   #10
QuoteOriginally posted by interested_observer Quote
haze grey and under way....
go navy!!!
05-19-2012, 01:11 PM   #11
builttospill's Avatar
I've done 30" and larger prints for art galleries with 8 MP files from my K10D including the single image in my gallery here. I recently did a 46" film print too for a gallery. 10 MP is more than enough. As mentioned above viewing distances help too. I've had quite a few images on billboards, but people don't usually see those up close.
My lab once told me a print would look bad with the file I sent, so I provided them with a bigger file. Pro labs will help you get it right.
05-19-2012, 01:44 PM   #12
dadipentak's Avatar
Even me (but keep your distance.)
05-19-2012, 02:01 PM   #13
westmill's Avatar
I used to print loads of 12" x 16" from the olympus E1... just 5 million pixel, and very sharp they were too i might add !
camera, pentax help, photography, question
2mp Ricoh RDC-5000 from 1999 ! jogiba Non-Pentax Cameras: Canon, Nikon, etc. 2 09-18-2011 09:15 AM
12.4mp vs 14.2mp, advice needed. softballdad57 Pentax K-r 10 09-11-2011 01:34 AM
8x10 crop lines on a focus screen Buddha Jones Pentax Camera and Field Accessories 3 06-01-2009 07:01 PM
3 FREE 8x10 prints heatherslightbox General Talk 2 09-11-2008 07:58 PM
Printing 8x10's from my K100D Ed in GA Pentax DSLR Discussion 5 10-01-2006 01:57 PM
All times are GMT -7. The time now is 01:10 AM. | See also: NikonForums.com, part of our network of photo forums!
