05-13-2012, 01:42 PM   #1
stopped down
Am still new to this can some one tell me what the meaning stopped down is it something to do with the lens thanks in advance
05-13-2012, 01:50 PM   #2
GabrielFFontes's Avatar
Stopping down the lens means closing the aperture by a portion...
05-13-2012, 01:51 PM   #3
Stopped down meaning not shooting at the lens's maximum aperture. So it a lens goes all the way up to F2.8, shooting at F4 would be stopped down by one stop, and shooting at F5.6 would be stopped down by two stops.
Normally when people say "shooting stopped down" they are referring to shooting in the lens's sweet spot (i.e. where it's the sharpest), which is usually in the F5.6-F8 range.
05-13-2012, 01:52 PM   #4
aurele's Avatar
let's start
On every lens, you can read the focal lengt in mm (like 28mm, 50mm, 85mm, 135mm, 200mm, etc ..).
You can read the biggest aperture available expressed like this 1:1.4 or 1:1.7 or 1:2 or 1:2.8 or 1:4, etc ...
This value is the widest aperture you can get on the lens. Basically if you use it, we say you shoot "wide open".
But you can choose a smaller aperture (like f4, f5.6, f8, f11, f16, f22, f32). When you choose any other value than the biggest one, we say that "you stop down the lens".
Commonly, the best sharpness and color rendering is obtain when stoping down a lens. Around f5.6/8/11 you usually get the best of your lens on any DSLR.
edit : pwnd !
05-13-2012, 02:05 PM   #5
QuoteOriginally posted by aurele Quote
let's start
edit : pwnd !
thanks for the great info am learning something new all the time cheers
05-14-2012, 05:12 AM   #6
aurele's Avatar
What i'm going to say isn't very original, but, if you have a manual with your DSLR, you should read it.
Pentax do some heavy manual for its DSLR, but they are quite easy to read and have plenty of information.
I don't say that because i heard often this type of question (forums are made to help everyone, and its great !), but because it will make you gain some time, and you'll be able to play more and better with your DSLR, and so, have more fun
05-14-2012, 05:20 PM   #7
I will do just finding the time to do so iv read some like you said its easy to understand cheers
Heart stopped Wired Pentax SLR Lens Discussion 17 12-15-2011 12:25 AM
K-x aperture problem: always fully stopped down on DA lenses amrocha Troubleshooting and Beginner Help 4 11-03-2011 03:47 PM
Mirror cycling on optical preview, stopped-down movie recording bwDraco Pentax DSLR Discussion 10 09-12-2011 06:50 AM
Pentax 6x7 TTL meter only works with stopped-down metering trip9 Pentax Medium Format 14 08-11-2011 08:22 PM
K10D stopped-down metering weirdness Duck Dodgers Pentax DSLR Discussion 15 12-21-2007 11:25 PM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
