05-14-2012, 06:58 AM   #1
Falld5's Avatar
K20D and sigma lens error
At a wedding shoot this weekend I had my Sigma 17-70 f2.8 mounted on my K20D. I also had my AF540fgz speed flash on my bracket. All working fine...and just as the bride was starting to walk down the isle, (not kidding here ) the K20D got an error message on the aperature screen F---. The camera totally froze, and would not fire AT ALL. Nothing...no matter what setting I flipped it too. (I had a backup that I was using for zoom shots and did get the bride...thank heavens.) Once I was in the back of the church, I disconnected the lens and flash from the camera, and reconnected everything, and that seemed to fix it. Also, I have to add...at the reception, I had on aperature priority, as I usually do, and let the camera pick it's own shutter speed. Had flash on aperature priority also, setting iso and aperature to camera settings. (which were about 800 iso and f/4. The shutter speed did not work properly, absolutely ruining the shot, shutter speed adjusting itself to .5. Does anyone know if this is due to the sigma lens on a k20d, or if this would be an internal camera body error? I can still return the sigma lens for a replacement but really like the quality of this lens. Any thoughts from anyone are really appreciated.
05-14-2012, 07:19 AM   #2
Sounds like there may have been a connection issue between the camera and the lens- I'd try cleaning the lens contacts.
05-14-2012, 07:35 AM   #3
sterretje's Avatar
Clean the contacts on both lens and camera. Try the Sigma on the other body (assuming it's a Pentax as well); that would eliminate one of the two as the culprit.
As this is an intermittent fault, long term testing is needed to figure it all out; bad contact inside the lens or body is also a possibility.
Note that flash does not have an 'aperture priority' mode; it's PTTL/TTL or Auto or Manual or SpotBeam. I assume you were in PTTL as settings were copied from camera to flash. In A mode, settings are not copied (at least not on K10D, not tested on K5).
05-14-2012, 10:58 AM   #4
Falld5's Avatar
Thanks to both replies. My appologies for making a mistake with my wording. I was using Manual mode on flash using the same aperature and iso as the camera. I'm aware that it doesn't have 'aperature priority'.
aperature, camera, error, flash, k20d, k20d and sigma, lens, pentax help, shutter, sigma, sigma lens
For Sale - Sold: Pentax K20D and Sigma 17-70mm f/2.8-4.5 Lens (CONUS) xyalek Sold Items 4 01-14-2011 10:55 PM
Would a SIGMA non-DG lens be a problem in a K20D? peru Pentax SLR Lens Discussion 3 09-12-2010 05:53 PM
TOKINA RMC 1:3.5/70-210mm PENTAX K-mount F error on my K20d gybp Pentax SLR Lens Discussion 3 12-10-2009 12:02 PM
K20D Error - Images cannot be stored mkz Pentax DSLR Discussion 5 07-20-2009 09:55 PM
K20d- Memory Card error iceemn360 Pentax DSLR Discussion 5 06-08-2009 11:34 AM
All times are GMT -7. The time now is 11:57 AM. | See also: NikonForums.com, part of our network of photo forums!
