05-14-2012, 07:19 AM   #1
Step-up/down rings?
Hi Guys
Lest I order the wrong ones, I wanted to get help on the precise step-up/down rings (aren't they also called step-up/down adapters? Great if someone can clarify that as well), so here's is where I request your expertise:
Camera - Kx
Lenses I wanna use for macro work - Takumar 105/2.8 (screw mount) and Takumar 135/2.5 (bayonet mount) - with Raynox DCR 250
As of now, I cannot fit the Raynox on any of those two lenses. The adapter that came with the Raynox doesn't fit the lenses either. Hence I suppose(please correct me if I am wrong) I would need step-up/down rings?
Which step-up/down rings should I buy to use with both those lenses? (Even better would be if someone can point to a link perhaps on ebay?)
Thanks Heaps.
05-14-2012, 08:25 AM   #2
RioRico's Avatar
The Tak Bayonet 135/2.5 has a 52mm front thread; the Raynox clip-on adapter should work. (It works on mine -- I just now checked.) The Tak 105/2.8 has a 49mm front thread. The Raynox optic has a 43mm rear thread. I use a 49-43mm step-down ring to mount my DCR-250 on 49mm-thread lenses. Just search eBay for "49mm 43mm step" and you'll find offerings, cheap. Good luck!
05-14-2012, 08:38 AM   #3
mikeSF's Avatar
thats the ring i bought too and it works well. previously, i was jamming the clips on the adapter to force it to fit but it is much better to get a proper fit with a ring
BTW, i use thatTak105 with a Raynox 150 and extension tubes and get good macro results:
05-14-2012, 08:48 AM   #4
Thanks Rio and Mike. You guys literally are champions to help someone this quick
Rio - Yes as you mentioned, the adapter that came with the Raynox fitted the 135. Previously I was looking to screw the adapter to the lens but than after reading that your fits, I saw that I could clamp it to the front of the lens. All good.
Mike - That macro picture is oh-so-awesome. As I said, you guys are champions
Now am off to look for subjects for my macro endeavours.
05-14-2012, 10:44 AM   #5
To continue using the Raynox clip-on adapter with the 49mm filter lens, you might consider buying an inexpensive 49-52mm filter adapter & maybe even leave it on the lens.
That way both your lenses would effectively have 52mm filter threads.
05-14-2012, 07:25 PM   #6
Thanks Newarts. Yes that's exactly what I am gonna do for the 105mm Tak.
05-15-2012, 11:33 AM   #7
Marc Sabatella's Avatar
I'd actually still recommend getting a stepping ring. That clip on adapter is bulkier and fiddlier to attach than I prefer. There isn't enough difference in FOV between 105 and 135 to be worth having both sizes of adapters around; I'd probably just get a 43-52 and use it with the 135.
05-15-2012, 11:49 AM   #8
Yes that's an excellent idea Marc, I totally agree that fat adapter is a bit of a pain to lug around and would surely prefer a stepping ring and have already ordered the 49 to 43 ring as suggested by Rio, but I will also go ahead with the 49-52 by Newarts and the 43-52 by you. Thanking You. (Though it would be something to track which ring is for which lens unless I leave them on the respective lenses )
05-15-2012, 02:34 PM   #9
QuoteOriginally posted by voyager13 Quote
For a long while I had almost all my lenses adapted to 55mm for historical reasons (58 or 62 might have been better). It was great; my filter life was a breeze!
After a while I got a few lenses with large filters & abandoned the standard filter ring size approach. That may have been a big mistake. I now spend an awful lot of time looking for the right combinations of adapters.
Dave in Iowa
05-15-2012, 07:51 PM   #10
I am afraid I am getting there too Dave I will try to take it as a learning process for now, but I know a time will come when spending time looking for the right ring will be absolutely boring.
lenses, pentax help, raynox, rings, step-up/down, takumar
For Sale - Sold: Misc Equipment - Flashes FGZ 540 Sigma 530,Step Rings, TeleconvCaps, Hoods, St mackloon Sold Items 12 07-18-2011 06:33 AM
Do step up rings affect focal length of Raynox on DFA100mmWR? JayR Pentax SLR Lens Discussion 3 06-23-2011 10:36 PM
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
Step-up rings MrTea Pentax Camera and Field Accessories 3 05-26-2008 12:43 PM
All times are GMT -7. The time now is 01:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
