05-14-2012, 12:48 PM   #1
K110D will not take picture id built in flash is 'up'
I have owned K110D for several years now-simple, basic and she does everything I could ask for. recently though |I have noticed that if I pop the built in flash 'up' the camera will not take a picture. if I depress the flash gently with the trigger depressed it gets to a position (flash almost shut down) and the camera triggers and takes a picture just fine. I have looked around the internet but haven't spotted this exact problem. I'm not sure if it is a simple 'something broken' fault, in which case I shall manage without the flash, or a technical, setting changewd type of fault. any of you kind people got any ideas please? I downloaded an upgrade a while ago I seem to remember to allow a 4Gb card, but I think it was still ok after that. many thanks, regards JD
05-14-2012, 02:03 PM   #2
I'm not all that familiar with the K110D, except to know that it is identical to the K100D, but sans SR. I have a K10D, which is of approximately the same period.
The only thing that springs to mind, other than a malfunction, is that perhaps you have the camera set in manual mode and the shutter speed greater than 1/180. No Pentax dslr will fire the flash at a higher speed than that. The converse may be true: if you have the builtin flash up, it won't fire the camera at a speed faster than 1/180.
When I get home, I'll try this with my K10D.
05-14-2012, 02:08 PM   #3
Aegon's Avatar
I have a K10D with a bad flash. When the flash is deployed the shutter doesn't operate. These types of things can happen.
I sent it in to CRIS (official Pentax repair) for a quote. In my case, which may be different than yours, the replacement components were quoted at $110. I declined replacement and had the camera returned to me. I continue to use the camera without flash.
I'm just adding my experience, it may not apply to you.
05-14-2012, 02:13 PM   #4
If it is a broken flash, don't bother spending any money to fix it, you can get a good hotshoe flash for roughly the same amount and have far more capability.
05-15-2012, 08:50 AM   #5
thank you
cheers people, I think it is most likely a malfunction; have tried and double checked shutter speeds etc, so will have to live without it. not the end of the world, have a flash already, just handy for parties etc. worse things happen, regards to everyone JD
05-15-2012, 11:30 AM   #6
Marc Sabatella's Avatar
Do be sure you have good / freshly-charged batteries. It takes more power to run the flash than just about anything else the camera does.
camera, fault, flash, k110d, pentax help, picture
Kr wireless wont flash without built in flash selected Phil_jman Pentax K-r 14 01-11-2014 03:47 PM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
K7 and Built in Flash GoldenRGuy Troubleshooting and Beginner Help 21 12-29-2010 06:49 PM
K7 built-in flash in M sinus007 Pentax DSLR Discussion 17 08-18-2010 08:22 AM
K-x built in flash blew up Billium28 Pentax DSLR Discussion 2 08-04-2010 07:25 PM
All times are GMT -7. The time now is 08:53 AM. | See also: NikonForums.com, part of our network of photo forums!
