05-17-2012, 05:08 PM   #1
K10D AF motor sound is horrible?
My friend just bought his K10D from another Pentaxian. I noticed that the AF motor is way louder than my K20D, especially when using a 28-300mm lens. Is it normal?
05-17-2012, 05:59 PM   #2
Its hard to say if its normal or not with out really hearing it. That said, my K100 is very loud compared to the K20 I just sold. That was one of the first things I noticed when I received the K20 the first time - it was really quite. Now, with my new K5, the K20 sounded loud. So everything is somewhat relative. That doesn't really answer your question, but the best I can do....
05-17-2012, 06:00 PM   #3
they should be about the same
05-17-2012, 07:12 PM   #4
QuoteOriginally posted by interested_observer Quote
I have K100D too, and K20D AF motor indeed is quieter, but this K10D AF motor is louder than both K100D and K20D
So, is there a possibility that the body is not in good condition? My friend could return it if so.
05-17-2012, 07:24 PM   #5
If it sounds like something is broken, then yeah, I'd just return it.
05-17-2012, 07:37 PM   #6
Compared my K10d with K-5 just now -- same lens. The pitch of the motors does sound a bit different, but basically they sound the same.
Now, the shutter is a hell of lot louder on the K10D, but not the AF...
05-17-2012, 07:44 PM   #7
The AF function works fine though, it focuses almost as fast as my K20D, and focuses fine, no B/F issue at all. I've tried kit lens, it sounded calm (just like K100D and K20D), but tried it with two versions on Tamron 28-300 when focusing from close to far, or the other way around, it gives 'louder' sound. So the loud sound comes out when using wider rage lens. The sound itself did not have 'cracking-broken' noise, it's just louder..
05-17-2012, 08:24 PM   #8
Wheatfield's Avatar
QuoteOriginally posted by minahasa Quote
It is what it is. Perhaps if you go out and take some pictures, you will find yourself doing less handringing.
05-18-2012, 10:39 AM   #9
Marc Sabatella's Avatar
You tried the same lens on both camera? O course, one lens on one camera might be louder than a different lens on a different camera, but that isn't just due to the camera. A larger/heavier lens will generally make noise than a smaller/lighter one, because it makes the motor work that much harder.
05-18-2012, 11:08 AM   #10
I tried the same lens on both, yes. I tried it again with different lens on both cams. Both lens are 28-300. I understand that bigger lens do make louder sound, the problem is the K10D gives louder sound than K20D (even louder than K100D) with the same lens.
af, k10d, motor, pentax help
K10D Autofocus Motor Anthony Visitors' Center 5 04-05-2012 12:32 AM
some horrible luck here irishwhite Pentax Film SLR Discussion 2 09-04-2010 03:34 PM
Horrible Dust on my K-x sensor gut1kor Troubleshooting and Beginner Help 7 07-24-2010 07:06 PM
K10D v 20D / Shutter Sound Emotive45 Pentax DSLR Discussion 71 03-04-2009 04:42 PM
Sound of K20D vs. K10D G_Money Pentax DSLR Discussion 9 08-26-2008 12:08 PM
All times are GMT -7. The time now is 09:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
