Originally posted by Mareket It's probably because the viewfinder can only show a DoF around an aperture of f/2.8, and the 50mm will be faster than that, so you can't truly see if it's properly in focus.
...This is a 35mm film camera with an old style focus screen. The DOF in the viewfinder will be the same as at the film plane for 1:1 image size (i.e. contact print).
I looked at the series on Flickr and to be honest, all look to be pretty soft with most being grossly OOF though there is a tendency to back focus (background in focus) on all examples. Here are my suggestions:
- Do your focus test on a flat subject having fine detail and high contrast, newsprint taped to the wall is a good target.
- Do your focus test in good light with camera on tripod (if possible)
- Use the focus aides in the viewfinder
- If you wear eyeglasses, have them on when focusing
- If possible, evaluate the negative using a loupe rather than a scanned image
Possible explanations:
- Bad scans. Focus is critical when scanning and the negative carriers for most consumer scanners do a poor job of properly positioning the negative
- Missing or damaged film pressure plate in body
- Body has been "serviced" and the focus screen installed upside-down or without its shims
To be very specific...it is highly unlikely that the lens is the cause of your problem. If you can attain focus and a sharp image in the viewfinder, the same should be true with the final image. That is why we use an SLR.
