05-22-2012, 06:30 PM   #16
MSL
MSL's Avatar
QuoteOriginally posted by David Bruce Kawchak Quote
Thank you MSL. I will do that tomorrow.
You're welcome. But it sounds like this won't be necessary if you've solved the problem for bracketed shots. My thinking was that maybe it was some weird buffer issue, and so it would show up whether it was a bracketed burst or normal one. I'd have to check the specs on the K20d, but on the K5 you can shoot both exposure bracketing and color bracketing and so you may have set one or the other to do something weird. Doesn't really explain the white line across the images though.
05-22-2012, 07:16 PM   #17
MSL The white line is bothering me. I will know tomorrow when I shoot some tests.
David Bruce.
05-23-2012, 06:35 AM   #18
Well it seemed too good to be true. I took a picture this morning. Pink sky, bright line along right edge and a horizontal whit line across image. Here is the photo.
David Bruce.
PENTAX K20D  Photo
05-23-2012, 07:02 AM   #19
MSL
MSL's Avatar
A lot of questions because you have only supplied one image. We really need to see the whole set, either posted here or linked here from another site,
Please show the single shot image of the same scene and the three images from the bracketed set - and if you shoot a burst set and it does something different, those too would be good. For all, please make sure we can see the EXIF data. From this single image it looks like a sensor problem, but if the single shot image is okay, there is something more complicated.
05-23-2012, 07:20 AM   #20
westmill's Avatar
Errrrr WOW ! mmmmm Im fairly sure this is a service repair problem !
That goes well beyond the scope WB etc.
There seems to be a strong vignette near the bottom centre too.
The white overexposed strip.... Im starting edge towards a problem with the shutter !
05-23-2012, 07:38 AM   #21
eddie1960's Avatar
QuoteOriginally posted by westmill Quote
yep shutter looks to be a good bet, It looks like a light leak did on film, but you'd need to have done something really harsh to get a leak on digital cameras
05-23-2012, 07:41 AM   #22
bimjo's Avatar
Does it do that with all your lenses, or just one lens?
05-23-2012, 08:15 AM   #23
The above shot is a single shot image. Bracketed shots don't look any better. Is does look like a light leak on an old 35mm film. It does the same thing with all my lenses. I have been taking a lot of 3 shot and 5 shot bracketed photos for HDR. Maybe I overworked the shutter.
05-23-2012, 08:16 AM   #24
I am sorry this is a bracketed shot. I will repost the images.
05-23-2012, 08:41 AM   #25
I just took 6 different shots- 1 single and 5 bracketed. I am posting them here These are the bracketed not in the correct order though
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
05-23-2012, 08:46 AM   #26
Here is the single image shot
PENTAX K20D  Photo
05-23-2012, 08:48 AM   #27
The exposure of the church is not even coming out right. I metered the church as opposed the sky. Church is too dark.
05-23-2012, 08:52 AM   #28
westmill's Avatar
If you look... its actualy the white strip which is correct. It seems the shutter starts off ok then decides to take a break and slow down some. From what bits you can see In the white stripe the WB and everything actualy looks fine.
Its certainly a repair job. watever the cause.
05-23-2012, 08:57 AM   #29
Yep I noticed that too. White strip looks correct. I must have worn out the shutter. So much a rating of 100,000. I am going to check what my shutter count actually is and post the number.
05-23-2012, 09:02 AM   #30
24,904 is my shutter count as of the last shot.
image, images, pentax help, shots
Tuning your glass chuckp8 Pentax K-5 13 12-17-2011 05:54 PM
Nature Testing the Whites eaglem Post Your Photos! 2 02-23-2011 07:05 AM
Will K-7 have AF lens tuning like the K20D? jsherman999 Pentax News and Rumors 17 04-27-2009 04:01 PM
K20D AF tuning with FA*80-200mm dsport Pentax SLR Lens Discussion 9 09-14-2008 11:49 AM
K20D with AF Fine Tuning? blende8 Pentax News and Rumors 12 12-17-2007 06:36 AM
All times are GMT -7. The time now is 10:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
