05-23-2012, 03:55 AM   #1
M43 on a C-Mount camera
Hello all,
Perhaps I'm trying to perform the impossible:
I'd like to connect an M43 lens to a c-mount camera.
Is that possible? was it ever done? and if so, what adapter do I need?
Thank you in advance.
05-23-2012, 04:14 AM   #2
The registers are close but the M4/3 is a much bigger mount diameter.
Camera Mounts Sorted by Register
The M4/3 mount would have to be in about the same position as the existing C-mount thread
It may be necessary to seriously modify either the lens or the camera.
You could consider using a PK or similar slr lens which has a longer register, allowing a simpler adaptor tube
Also here is a cine zoom lens with a longer register adapted to M4/3
https://www.box.com/s/de12b7d6ffc983d748de
Here is a home made adaptor for longer register PK lenses to M4/3 - fairly straightforward
https://www.box.com/s/db2d50c7edecf721ca74
Good luck with your project
c-mount, camera, m43, pentax help, photography
Sensor Difference: Which is closer? APS-C to a M43 or M43 to a Digital Camera rustynail925 Photographic Industry and Professionals 6 09-09-2012 05:36 AM
Some thoughts about a m43 system farhagh Non-Pentax Cameras: Canon, Nikon, etc. 72 05-13-2012 02:49 AM
C mount > M43 > K/M42 duron Pentax SLR Lens Discussion 5 08-14-2011 08:24 PM
For Sale - Sold: FotoDiox K-mount to m43 mount adapter w/ aperture control deejjjaaaa Sold Items 3 08-04-2011 10:06 AM
A reason to get an m43 camera… joakimfors Non-Pentax Cameras: Canon, Nikon, etc. 8 03-03-2010 05:54 PM
All times are GMT -7. The time now is 04:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
