06-04-2012, 04:55 PM   #1
jpzk's Avatar
DA*300/4: very slight movement in focusing ring.
This is the first time I am aware of this, with my DA*300/4:
When I gently push sideways or top-to-bottom/bottom-to-top on the focusing ring, I feel a very tiny amount of "movement".
Is this something I should be concerned with or is this "minimal" movement normal?
The lens is behaving as it should though with no particular loss of IQ/stability ... whatever.
Here is a visual explanation:
06-04-2012, 05:00 PM   #2
borno's Avatar
Mine did that too, I'm pretty sure it's normal.
06-04-2012, 05:08 PM   #3
mine too
06-04-2012, 05:12 PM   #4
rhe
rhe's Avatar
Mine does that also!
06-04-2012, 05:37 PM   #5
joe.penn's Avatar
Mine does not do that...
06-04-2012, 07:21 PM   #6
jpzk's Avatar
Thank you all !!
I was starting to wonder if this was a cause for alarm.
I can now get to bed!
Cheers.
JP
06-04-2012, 07:28 PM   #7
joe.penn's Avatar
May not be cause for alarm, but it is definately "not" normal unless it is a QC issue - seeing that I have yet to see a QC complaint on a *300, this could be the first QC complaint about this lens. Think about it, a "weather sealed" lens that has abnormal play in the focus ring.
Sleep tight JP, I will seeing there is no play in the copy I just got...
06-04-2012, 07:30 PM   #8
joe.penn's Avatar
Oh, BTW: You can call CRIS and a technician will tell you if this is a logged flaw or not...
06-04-2012, 07:31 PM   #9
dgaies's Avatar
QuoteOriginally posted by joe.penn Quote
Interesting. I was about to reply that as I recalled there was a little bit of play in the focus ring of the three different copies of the DA*300 I've owned over the past three years. Perhaps I was wrong abut the third copy
06-04-2012, 07:47 PM   #10
joe.penn's Avatar
Ya, no play like he described I am handling it again and it is pretty tight. (Unless we are talking about different play)
06-04-2012, 07:50 PM   #11
LFLee's Avatar
not to steal your thread, but my 16-50 also wobble on the extension part. Have me worry too.
06-04-2012, 07:53 PM   #12
jpzk's Avatar
Do you have the number to call? I will do that.
JP
06-04-2012, 08:01 PM   #13
joe.penn's Avatar
PENTAX SERVICE DEPARTMENT
250 North 54th Street
Chandler, AZ 85226
Telephone: (800) 877-0155
They are pretty good - it's worth a shot if it helps you feel better, they may just tell you it's normal (lol, now I am checking some other lenses)...
06-05-2012, 06:16 AM   #14
jpzk's Avatar
Chandler, AZ 85226
Thanks for the info.
I thought of calling Pentax Canada but they are usually useless to give ANY information via phone calls; they will also not let you talk to a technician - "just send the equipment" is the usual response.
JP
06-05-2012, 06:18 AM   #15
jpzk's Avatar
QuoteOriginally posted by LFLee Quote
It's not really a "wobble" that is on my DA*300/4 ... rather a very tiny amount of movement in the focusing barrel.
But it would be interesting to find out what yours really does and if this is problematic.
JP
da*300/4, movement, pentax help
Issue with 01 lens focusing ring Paolo.Bosetti Pentax Q 16 04-07-2014 12:28 AM
D FA 100mm Macro WR jerky focusing ring savoche Pentax SLR Lens Discussion 6 05-24-2012 01:24 PM
Anybody know off hand how to remove the focusing ring on an A 50mm f/2.8 macro? Steinback Pentax SLR Lens Discussion 3 09-17-2011 07:33 PM
DA 55-300 Tube Movement COULDBE2 Pentax SLR Lens Discussion 4 06-27-2010 01:47 PM
People Slight Grimace, Slight Smile jzietman Photo Critique 11 04-20-2010 11:52 AM
All times are GMT -7. The time now is 02:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
