06-12-2012, 04:54 AM   #1
Every Button pressed sounds like a photo has been taken
I have had a K5 for over a year now. Love it.
BUT.....over the last few weeks it has started to give me a problem. It doesn't seem to matter which button I press or whether I try and take a photo I get a sound as if I had taken a photo. But a photo is not actually taken. This happens regardless of which lens I use and also happens with no lens attached. So it cannot be due to dirty contacts on the lens.
The problem is intermittent (inevitably) and so far I have not been able to establish what sets this problem off. I have tried with a fully charged battery or a partially discharged battery - doesn't seem to matter. Also taking the battery out and then reinserting it. Sometimes this stops the problem for a while. Also switching the camera off can help but not always.
Am in Spain at present, could heat affect it? But I'm fairly sure this problem has happened in England with no high temperatures.
Hope I've clearly explained the problem. Any help or advice would be appreciated.
Cheers....John
06-12-2012, 05:32 AM   #2
sterretje's Avatar
Do a search for 'mirror flop'. If I recall correctly, a PCB needs to be replaced. Warranty affair (and EU law gives user protection for 2 years if I'm not mistaken, even if the warranty has ended).
06-12-2012, 06:07 AM   #3
darrenleow's Avatar
Something like this?
I sent mine in to Pentax couple of times and eventually they got it fixed after quite a long wait.. Not sure if it was due to parts or them trying different fixes, but it eventually worked properly again
Here's what they fixed according to the report:
REPLACED APERTURE/SHUTTER F.P.C.
REPLACED TIMING CAM GEARS
ADJUSTED TO MANUFACTURERS SPECIFICATIONS
GENERAL CHECK AND CLEAN
RESET ALL
06-14-2012, 01:37 PM   #4
Yes - exactly like that Darren. I can often take a couple of shots then it goes into 'Mirror Flop' mode. Fortunately it's still under warranty (not over a year as I first thought) and I'll sort this out when I'm home from holiday in Spain. I'll make a note of what was fixed on your camera!
Thanks and thanks to sterretje. So frustrating - I still have my K7 - wish I'd bought it with for backup! Hindsight is wonderful.
John
12-02-2012, 01:41 PM   #5
My K2000 just did this yesterday. Non-stop. No taking pics in between. I have 2 sets of rechargeable batteries that I use. I rotated out to a different set and all seems ok right now.
12-03-2012, 10:09 PM   #6
I've written of this before, but paraphrasing. My experence, K-r mirror flopped. Things that seemed related, 1) low battery charge. Recharged battery and problem was reduced. 2) type of lens installed, Installed a lens with a metal base instead of the DAL it came with and problem went away. 3) Lens mount and lens contacts dirty. After cleaning problem ended, even when using the DAL kit lens.
I haven't been able to investigate further because after cleaning lens mount contacts the problem has not reoccurred. Low battery charge definitely made the problem worse.
Results on K-5 may be different. Some will say I'm wrong and I say to them PUTTH! Worked for me, that's all I know.
battery, button, help, lens, matter, pentax help, photo
Half Pressed Snap - Keep Snapping crusniq Pentax K-r 3 05-22-2012 06:09 AM
Green button or +/- button for meter? kidblue Pentax SLR Lens Discussion 15 07-29-2011 07:10 PM
Sounds like an old joke seacapt General Talk 18 06-29-2010 06:09 AM
Well I pressed the button and bought an EOS 7D Big G Non-Pentax Cameras: Canon, Nikon, etc. 48 04-01-2010 01:51 PM
exposure changes when shutter pressed? adwb Pentax DSLR Discussion 4 02-26-2010 06:15 PM
All times are GMT -7. The time now is 05:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
