06-14-2012, 02:44 AM   #1
Filter usage
i'm interested to buy some filters, mostly for outdoor photography, sky. what filter could you recomend? and is it worth to use few filters at same time? sorry for my english
06-14-2012, 07:27 AM   #2
RioRico's Avatar
Welcome to the forums! Use a CPL (circular polarizer) to reduce glare and reflections and to increase contrast. Many other filters exist for various uses, but that is really all you need. You usually should NOT use more than one filter at a time. More layers of glass in front of the lens will hurt image quality. Look for a filter that is MC (multi-coated) to reduce flare. Cheap uncoated filters can also hurt image quality. Good luck!
06-14-2012, 08:07 AM   #3
Anvh's Avatar
CPL also removes glare making the colour of vegetation more vibrant for example and the sky deeper of colour.
polarization
06-14-2012, 08:10 AM   #4
BigDave's Avatar
A few other filters to consider:
A. Neutral density- somewhere between a 3 to 4 stop reduction to the exposure (ND 0.90 to 1.20). This will help you get to long exposure times when lighting is a bit bright
B. Graduated filters- Neutral density and warming (yellow and red) to balance exposure sky-to-ground and saturate the reds and yellows in sunsets. The square/rectangle ones are best for this so you can choose the transition zone.
With the use of the Circular Polarizer, this should take care of most everything, until you want some more special effects. Then the skies the limit!
Always look for good double multi-coated (front and back) filters. They cost more but reduce ghosting and unsharpness caused by it.
Regards,
06-14-2012, 08:23 AM   #5
at this moment I have Hoya HMC UV filter 62mm. and which one will be better: hoya HRT UV-CIP-PL or hoya HRT CIP-PL? or maybe enough only UV filter?
06-14-2012, 09:00 AM   #6
RioRico's Avatar
There is NO optical need for a UV filter on a digital camera unless you are around 4500m / 15000ft or higher elevation. A Skylight or UV or clear glass filter can protect the lens against spray or sand or debris, but is otherwise useless. UV is already blocked in the sensor. Your most useful filter for handheld photography will be a CPL (circular polarizer) which is superior to a PL (linear polarizer).
06-14-2012, 09:06 AM   #7
thanks for the answers
06-14-2012, 09:50 AM   #8
Marc Sabatella's Avatar
And no, don't stack filters unless absolutely necessary. each filter in the chain degrades IQ by some amount. So you want the fewest number of filters that will solve the particular photographic you are having that causes you to consider a filter in the first place.
camera, filter, filters, pentax help, photography
Anyone have link for usage contract K-9 Photographic Industry and Professionals 2 02-16-2012 04:23 PM
DA 35mm f/2.4 usage advice wedge Troubleshooting and Beginner Help 14 07-05-2011 04:22 PM
How to extend battery usage pmastello Pentax K-5 2 05-29-2011 06:33 AM
The usage of OK button NguyenP Pentax DSLR Discussion 4 12-28-2010 09:58 AM
newbie question about remote usage on k-x 96p993 Troubleshooting and Beginner Help 2 08-09-2010 10:06 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
