06-15-2012, 03:56 PM   #1
Enable remote trigger on K5
I bought a real cheap remote trigger labeled "For Pentax" on ebay. However I was not able to get it to trigger my K5. I tried pointing it to the front and back of the camera but nothing happens when I press the button on the remote. Is there some function that I need to enable to make the K5 respond to the remote? Or maybe its just a bad remote?
06-15-2012, 05:37 PM   #2
JimJohnson's Avatar
You have to first tell the camera that you want to use a wireless remote. Look for the self-timer button on the back of the camera. It will give you a number of options including using an IR remote.
06-16-2012, 05:58 AM   #3
Thank you very much Jim. I was able to do like you said and it works perfectly. Thank you sir!
k5, pentax help
Trigger Happy Camera Remote (iOS and Android) Trig Pentax Camera and Field Accessories 5 03-05-2012 10:26 PM
Flash and Remote Trigger arnie0674 Photographic Technique 8 03-03-2012 04:06 PM
Remote trigger not working in K7/K5 hotshoe? amoringello Pentax Camera and Field Accessories 14 09-02-2011 03:46 PM
Remote trigger vs onboard k-x wireless trigger irishwhite Photographic Technique 3 03-06-2011 04:36 AM
Remote flash trigger problem stjohndunn Pentax K-5 2 01-04-2011 07:39 PM
All times are GMT -7. The time now is 02:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
