06-16-2012, 03:47 PM   #1
userage's Avatar
Pentax ME not metering correctly?
I tried my ME Super and K-x on the same settings for Aperture and ISO, and my ME had a faster shutter speed by 3/4 stops. What could be causing this? :S?
06-16-2012, 06:55 PM   #2
Meter both against a blank wall in even light with the same lens. It was not unusual back-in-the-day for meters to be off by a 1/2 stop or so, even brand new.
06-16-2012, 07:00 PM   #3
What batteries are you using?
06-16-2012, 07:27 PM   #4
Good point. Alkaline batteries drop voltage as they discharge. Silver cells do not.
06-16-2012, 07:37 PM   #5
And some are the wrong voltage to begin with. The ASA dial can be used as an EV compensator.
06-17-2012, 05:12 AM   #6
userage's Avatar
I am using Alkaline batteries actually, they're some cheap ones which were suppose to be temporary. So should I just use the ASA dial to compensate for now and get some new batteries?
I checked it again and it seems to be a stop off, I thought it was quite weird I was getting shutter speeds of 2000 on a cloudy day with F8. :S
06-17-2012, 07:49 AM   #7
QuoteOriginally posted by userage Quote
Ummmm...that would be a little more than 1 stop off.
Fresh alkaline batteries should work fine, though silver cells are highly recommended both for life span and performance. Did you compare the two cameras against a blank, evenly-lit surface? The reason why I suggested that is that the metering systems are quite different between the two bodies. Your ME Super is strictly center-weighted averaging with a bias to the lower part of the image. Even with your K-x in center-weighted mode, the pattern is likely not quite the same. Compare readings against a uniform target and then use the film-speed dial to compensate. You can also use the exposure compensation feature (duh!) to accomplish the same thing.
06-17-2012, 08:07 AM   #8
userage's Avatar
It was off by one stop when I tried it against the wall, I know it was off by a lot more when I was out.
06-17-2012, 08:57 AM   #9
What are the exact batteries you have? What is the number on them? What is the supposed voltage?
06-17-2012, 06:11 PM   #10
creampuff's Avatar
The ME Super is a very old camera... are you certain there isn't a problem with the camera's meter?
pentax help
For Sale - Sold: Pentax A 35-105 (A Function not working correctly) zbrueningsen Sold Items 4 06-11-2012 12:21 PM
P67 TTL prism not metering correctly? noodle0 Pentax Medium Format 5 09-17-2011 10:51 PM
New K5 - doesn't seem to be focusing correctly? NicoleAu Pentax K-5 24 08-07-2011 06:57 PM
Shutter count... am I reading correctly? Ubuntu_user Pentax DSLR Discussion 9 12-30-2010 01:17 PM
metering, how is this done correctly? wed7 Troubleshooting and Beginner Help 1 03-15-2010 10:25 AM
All times are GMT -7. The time now is 03:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
