Originally posted by Marc Sabatella
NO way would I spend over $1000 on lenses and come away with nothing wide angle. 28-75 shouldn't be on the list unless you plan to spend even more to address that need. Perhaps even just the kit lens.
I've used the Tamron 28-75mm with the kit lens, and with the 16-45mm and with the DA15mm. All of those combinations work reasonably well. Right now, I'm using the Tamron with the DA15, which is a wonderful combination, but you gotta remember that 15mm is usually too wide for people photos, and you're better off using 28mm. Surprisingly, 28mm is wide enough for almost all people shots (its ideal actually), and some scenery shots. 28-75mm works fantastic for portraits.
When I owned the 16-45mm, I really liked the 16-45mm+28-75mm combo; both lenses are about the same size, but the 16-45mm is considerably lighter, and both give excellent results. I just like the DA15mm even more, because its the only compact ultra-wide DSLR lens made, and I've gotten some really wonderful shots with it. I'm considering adding the DA21 to the mix.
- Sheldon
