06-29-2012, 04:55 AM   #1
Flashing LCD and Top Panel
Hello!
Just received my K-5, Formatted my Sandisk 16gb extreme card and inserted the charged battery. I took several test pics in the auto mode (green) and also did a very short movie clip, all seemed to be fine, then I noticed the panels started flashing and red auto focus points flashing in the veiwfinder. How does one correct or stop the flashing. Do I need to do a firnware update? Please advise, if you can. Thanks
06-29-2012, 07:33 AM   #2
sterretje's Avatar
Can you still switch it off or does it keep doing 'the flashing'. If so, remove the battery and try again. If it keeps on doing it after this, ship it back and get it replaced. I don't think that a firmware update will help in that case (if accessible at all).
06-29-2012, 07:53 AM   #3
Flashing LCD and Panel
Thank you for the reply, oddly enough I turned the ring on my lense closest to the camera (18-135mm Pentax WR ) and it seemd to have stopped the flashing. It is possible I was overiding the auto settinds somehow? I have taken several shots and no fllashing.
auto, camera, pentax help, photography
red flashing in lcd screen rca1 Pentax DSLR Discussion 5 04-07-2012 11:11 AM
How do i turn off the rear LCD panel derek45 Pentax K-r 20 04-06-2012 12:46 PM
LCD Panel Issue sasikantt Pentax DSLR Discussion 3 06-28-2011 09:30 AM
The missing top LCD panel mrbrightside Pentax K-r 17 12-23-2010 01:14 AM
New K200d user - thank god for the top-panel LCD MiguelATF Pentax DSLR Discussion 2 07-12-2010 02:16 AM
All times are GMT -7. The time now is 08:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
