Hello fellow Pentaxians..!
Anyone knows how to troubleshoot a lens problem?
Here's the problem:
I have a Tokina 28-70mm f2.6-2.8 at-x pro lens, it was working perfectly on all of my Pentax DSLRs. One day, I got caught in a strong rain, and the lens got some rain water, but I'm not sure that the lens was got really soaked because I protected it with cloth and with some plastic.
So, after two days, suddenly
the lens' auto focus and the A-setting of aperture doesn't work. I know that it's not a camera error because my other auto focus lenses works perfectly on my Pentax K-7. Anyway,
If I install the Tokina 28-70mm on the camera, switch it on, then the focal length selector appears as if I were installing a full manual lens. It seamed that the lens' contacts/electronics got a problem. I tried to dry the lens' aperture ring for days (even used a hair dryer then pointed it at the aperture ring area) because I thought it might had a soaked parts inside, but still the AF and A-setting of aperture doesn't work. Good thing that I can still use the lens but in full manual control, manual focus and manual aperture using the aperture ring...
Anyone had an experience with this kind of problem and solved it?
I'm thinking to ship the lens for repair, but before doing that, I'm thinking that it might be a solvable problem with DIY or has some simple solutions for it...
Thank you in advance!
Richard B.
