07-03-2012, 03:38 PM   #1
PenPen's Avatar
Help w/new lens
Hi.I purchased a Sears 135mm F/2.8(private party) prime macro lens for my K-m. I set the camera on M and the aperture ring to A. The lens just shuts down the camera and the blinking on the screen of "f/stop" is all that I can get out of it.I know the lens can be used because it can and has been used on k-5's. Please tell me how I can fix the problem?
BTW:The first time I connected the lens to my camera,it got stuck.Really stuck,but I finagled around with it and got it loose.My other Sigma and Pentax lenses are still working fine,so I don't think I killed my camera!
Thank you to all who reply!
PenPen
07-03-2012, 04:27 PM   #2
jatrax's Avatar
Try reading this
I think you need to turn on "use aperture ring" in the menu. I do not know where in the menu that is on the k-m, though. I assume that lens is either a 'k' or 'm' series.
07-03-2012, 04:59 PM   #3
QuoteOriginally posted by PenPen Quote
PenPen
Google "ricoh pin" - that may be the issue. Do not mount the lens again until you check to see if it has this pin on the mount. If it does, it will get stuck in the AF screw drive.
EDIT: try these:
http://www.theatreofnoise.com/2008/05/ricoh-lenses-on-pentax-cameras-ricoh.html
http://www.techtheman.com/2009/12/ricoh-pin-and-pentax-kr-mount.html
07-03-2012, 05:20 PM   #4
PenPen's Avatar
PenPen says:
Thank you !! Set the A ring to permitted,and now the lens and camera work just great!
Thank you so much!!!
07-03-2012, 05:37 PM   #5
jatrax's Avatar
Can you verify that the lens has an 'A' position on the aperture ring? If it does and you have it set to 'A' then you should be able to change aperture using the camera dial assuming everything is working correctly. If it does not have an 'A' position then you have what is commonly called an 'M' or 'K' series lens with no electrical contacts.
camera, lens, pentax help
Keep K-x buy premium lens, get K-r and get good lens, get the K-7 w/ lens or K-5? crossover37 Pentax DSLR Discussion 19 02-06-2011 10:38 PM
All times are GMT -7. The time now is 08:13 PM. | See also: NikonForums.com, part of our network of photo forums!
