07-06-2012, 12:33 AM   #1
K-7 autofocussing or ?
Hi, I'm having trouble with my K-7 .. I have used it A LOT!!! for the past two years ....and now am finding that suddenly the camera will shut off .. even wiith an almost fully charged battery ... esp. has trouble focussing on small distant objects .... as in shooting while riding in a car ... sometimes i can hear a motor whirring inside ... if I quickly turn off the camera and take out the battery and put it in again and use manual focus, I can avoid the complete death of the battery.
I am living in Kazakstan and have used the camera almost daily for 2 years ... so may the motor is just tired .. or the batteries will no longer hold the charge .. no Pentax dealer here .... any suggestions???
Thanks!
07-06-2012, 01:16 AM   #2
hcc
hcc's Avatar
Does it happen with all your lenses?
I had a somehow similar problem with my K-01 and DA40mm xs. The lens fitting was very tight and I did not lock up properly the lens. In turn the AF motor was turning on and on ...
At the end I tried another lens and I realised that it was my mistake.
Hope that the comment may help.
07-06-2012, 02:35 AM   #3
Original battery? If so, could be it's a simple matter of it coming to the end of it's service life. If it's dying it could easily show a full charge intially then discharge rapidly.
battery, camera, k-7, motor, pentax help, trouble
K10D vs Canon 5D - Autofocussing anomalies ? Confused Pentax DSLR Discussion 41 04-08-2009 09:23 AM
All times are GMT -7. The time now is 09:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
