07-09-2012, 03:20 PM   #1
BerndM's Avatar
Long Bulb exposure on a K2000
I plan on using my newly acquired K2000 on my telescopes.
I need to be able to open the shutter for several minutes at a time and since there is no threaded cable release on the shutter button, I'm at a loss on how to accomplish this. From what I've been able to gather, the Pentax Remote F probably will not do what I need. I do NOT want to have to HOLD the silly button down for that long.
I'm contemplating making a bracket that will permit me to use my old mechanical shutter cables from my film SLR cameras.
Any comments or suggestions would be most appreciated.
Thanks
Bernd
07-09-2012, 04:03 PM   #2
GabrielFFontes's Avatar
1 - Buy a 2$ chinese IR remote.
2 - Set your camera to 2touch bulb mode. [C3.15, at least on my K-r]
3 - ????????
4 - Profit!
07-09-2012, 05:00 PM   #3
mattt's Avatar
Don't forget about "dark frame subtraction " I was stymied by it. I thought my Kr had a bug or was frozen, but it was creating the dark frame which I had never encountered with sub 30s exposures.
Be sure to post some of your shots!
07-09-2012, 05:15 PM   #4
littledrawe's Avatar
QuoteOriginally posted by GabrielFFontes Quote
May not be available on the k2000, it is very basic. If not, there is a thread or two here showing someones DIY shutter button holder that slips into the hotshoe.
07-09-2012, 07:30 PM   #5
K57XR's Avatar
Reading through the manual I don't think the 2-touch (Shutter open/close) in bulb mode with an IR remote is available on K-m/K2000. It may be crude but if you can find a miniature c-clamp and clamp the button on the remote for as long as you want your exposure. The remote doesn't have to be in front of the camera; just somewhere adjacent with direct line of sight with the sensor. Once you're done with your exposure you can "un-clamp" the remote or simply move it away from the camera.
As mentioned above, if you're not familiar with DFS (Dark Fram Subtraction) you may want to do a research on the subject. I don't know about the k-m but the K-x/K-r (and perhaps other higher models) will perform DFS for exposure >30 seconds. Cheers.
07-09-2012, 10:55 PM   #6
BerndM's Avatar
Thanks VERY much for your comments guys. I will give serious thought to everything! The K2000 doesn't do DFS but that's OK. I was thinking of making a shutter cable bracket to attach to the 1/4-20 tripod hole and I never considered using the flash shoe. That would actually be a simpler arrangement..
I have 2 dedicated astro ccd cameras but they are a PIYA to use what with the laptop and all, so I thought the DSLR approach would be a lot more streamlined.
Thanks again
07-10-2012, 05:56 AM   #7
In the appendix section my k2000 manual says the remote control F is compatible with this camera. Now how that works in bulb mode this page https://www.pentaxforums.com/forums/pentax-beginners-corner-q/191964-long-bul...ure-k2000.html does not say.
07-11-2012, 03:49 PM   #8
BerndM's Avatar
I called Pentax and the really helpful guy there sais YES, the K2000 WILL do long exposures with the Remote F unit. GREAT!!!
BUT he called me back the next morning to tell me that he was mistaken, it will NOT do long exposure.
So I made myself a metal bracket which attaches to the hot shoe and permits me to use my old locking cable release from the 35mm SLR days.
Works just fine
Now another issue has popped up that I haven't been able to find a solution for, so here I am....
When the K2000 is in manual mode and the camera is attached to the back of my telescope using a T adapter, the camera asks for a lens focal length.
The highest it will go is 800mm, not nearly close to what my telescopes are.
Does this even matter since I am focusing manually and only using the camera in MANUAL mode??
Thanks!
Bernd
07-11-2012, 06:10 PM   #9
mattt's Avatar
Its for SR
If you are on a tripod, no need to worry, SR should be off.
Enjoy
07-11-2012, 07:31 PM   #10
BerndM's Avatar
Thanks Mattt
I was hoping that was the answer. So that's one more issue laid to rest.
bulb exposure, button, camera, k2000, pentax help, photography, shutter
K20D bulb mode, the safest, longest exposure? minahasa Pentax DSLR Discussion 2 06-21-2012 08:52 AM
Long exposure / provia 200 : how to know the good exposure compensation ? aurele Pentax Film SLR Discussion 3 02-18-2012 06:58 PM
Upgrading from K-7 to K-5? (Bulb exposure) Wisco Pentax K-5 11 05-23-2011 03:34 PM
bulb mode vs timed exposure PaulfromTexas Photographic Technique 8 02-28-2011 12:26 PM
Bulb mode on K200D and very long exposure madbrain Pentax DSLR Discussion 34 07-31-2008 01:06 PM
All times are GMT -7. The time now is 03:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
