07-09-2012, 08:59 PM   #1
Pepe Guitarra's Avatar
MC Cosinon-T 200mm f/4 Cosina Lens Made in Japan
I just bought this lens (MC Cosinon-T 200/4 Cosina), I paid $7 plus $8 shipping, it looks in great shape, clean, almost new and when I move the aperture lever, it opens it fine. It focus well, but when I try to stop it down with the green button, it cannot be stopped down. It always shoot with wide open. I know the aperture is working because it manually open and closes. I a using the Pentax K5. Any advice?
PS. I also bought the same lens from a pawnshop for $1, but it was damaged, the focus was loose, and the aperture lever did not open the diaphragm.
I really appreciate your advice, the photos wide open are OK, as far as i can see in the short period of time at night.
Here is the lens.
07-09-2012, 09:20 PM   #2
I believe that you are going to have to operate the lens as a fully manual lens. Which means to stop down, you have to do it the old fashion way, and actually turn the aperture ring to the desired f stop, then meter with the green button (setting the shutter speed and ISO depending upon your selected mode - essentially AV or M) and shoot. It looks like a very nice lens and you really can't beat the price.
I think that this is your lens...Not the world's best optics - but a 7 rating at a couple of dollars is not bad. You can have a lot of fun with it and it looks very clean!
07-09-2012, 09:26 PM   #3
I usually shoot manually. However, when I set up the aperture with the aperture ring, focus and push the green button, it does nothing. So, it does not stop down. Therefore, the shot is taken wide-open. I compared it with my other (most of them) manual lenses and it looks fine, when out of the camera, it does open the diaphragm with the lever. I tried using the Pentax 1.7xAFA to see if I get some traction but nothing. It is like if the lever never engages with the camera.
07-09-2012, 10:15 PM   #4
dms
I had a similar problem with a 50mm f1.7 (M) lens that I purchased on ebay. After a while it exhibited the symptoms you describe.I pushed (by hand) on the aperture setting lever--either outwards or inwards--forgot which and that did the trick.
07-10-2012, 04:07 AM   #5
Dear Pepe.
I had similar thing with Porst 55/1.2. The thing is that the lens mount is covered with some sort of dye that did not conduct electricity. So, camera can not recognize the lens to be mounted. What I did is I scratched the stain from the mount where the contacts on the body are located. Some people are using foil just sticking into this place. I tried that but it did not work.
Hope this would be helpful.
Yuriy
07-10-2012, 04:31 AM   #6
cmohr's Avatar
I have the same thing with my old Cosina 50/1.4, aperature works fine on my *istD, but not on my K-5 or K-7. I think its the crippled mount of the newer camera's.
07-10-2012, 04:33 AM   #7
kcobain1992's Avatar
Check the EXIF from photos taken with the lens. If it says "M42 or no lens", rather than "K or M lens", it means that tin foil, conductive paint, scratching or whatever will make the camera accept the lens as K-mount.
Had the same thing with a Takumar which the camera believed was K-mount.
aperture, camera, cosina, cosinon-t, flickr, focus, lens, pentax help, photography
For Sale - Sold: Pentax FA 31mm Ltd made in Japan (US) TGaa Sold Items 2 08-16-2010 02:01 PM
43mm ƒ1.9 - Made in Japan Vs. Made Wherever today? Quality Issues? PentaxForums-User Pentax SLR Lens Discussion 6 05-09-2010 01:49 PM
Can I use this cosina cosinon lens? Morb1 Pentax SLR Lens Discussion 4 08-14-2009 01:06 PM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
