07-10-2012, 06:41 AM   #1
Is my Sanyo eneloop charger NC-MQN04E faulty?
I have 3 sets of (4 AA) Eneloop batteries and the Sanyo MQN04E charger that came with the set.
The eneloops are of 1.2V, Min. 1900 mAh and the charger output is 2.4V, 250mA x 2(AA).
The problem is with the LED which always shows green. Even after plugging it for 2 days it shows green and there is no way to know if the batteries are charged or not.
Is the charger faulty? Should I change it?
How long does it take for this charged to recharge 4 AA eneloops which are completely depleted?
Cheers
Guna
07-10-2012, 06:53 AM   #2
The charger that you have will only charge in pairs of batteries. A better charger will charge each battery individually. Maha, and others make such a charger. The manual that came with the charger will state the charging times. Google - Sanyo Eneloop charger NC-MQN04E - to find a PDF manual online. Have to tested the voltage of each cell after charging?
07-10-2012, 08:08 AM   #3
aleonx3's Avatar
My recommendation is to get a better charger that has individual circuitry; it is worth the money and less frustration. Also, your rechargeable batteries may run longer without hassle.
07-10-2012, 02:12 PM   #4
lammie200's Avatar
I don't know what model number my Sanyo Eneloop charger is, but it seemed like it was defective. With all four batteries in only one green led would light. It would blink all the time. Also I was getting very quick yellow battery indication on my K-r. Yesterday I charged the Eneloops with an Eveready charger and so far so good.
07-10-2012, 03:23 PM   #5
vladimiroltean's Avatar
If this is of any help, my charger behaves exactly the same. However, after approx. 12 hours, the green lights disappear, so I believe they are meant to be green while the batteries are charging.
07-10-2012, 08:49 PM   #6
Thank you. It seems my charger might be defective after all. Need to buy a good one.
Guna
batteries, charger, eneloop, eneloops, pentax help, sanyo
Sanyo XX Battery - based on Eneloop technology Docrwm Pentax Camera and Field Accessories 2 12-02-2011 05:44 PM
Sanyo Eneloop with Solder Tabs? SOldBear Flashes, Lighting, and Studio 7 07-23-2011 08:22 PM
Some alternatives to Sanyo Eneloop? DavoMrMac Pentax Camera and Field Accessories 28 02-01-2010 03:47 AM
Sanyo Eneloop charger mopar_man Pentax Camera and Field Accessories 13 08-05-2009 12:39 PM
Sanyo Eneloop question. Gord K. Troubleshooting and Beginner Help 9 08-04-2009 08:58 PM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
