07-10-2012, 06:02 PM   #1
manual lens on K-10
I have the K-10 body. And I use manual lens on it a good deal of the time. Never had a problem, turned the dial to "M", "M" focus & I could adjust the shutter speed by using the front dial & adjust the f/stop manually on the lens. No big deal. But, today, I turn the dial to "M", "M" focus but it will not let me adjust the shutter speed. The "f/stop" flashes on the display panel. If I put the lens that came with the camera on, I use the "M" to change everything by hand. Does anyone have an ideal what may be the problem? Thank you in advance.
pdl1945
07-10-2012, 06:07 PM   #2
Canada_Rockies's Avatar
I suspect you have the f/stop ring on "A". You have to have it on a real f/stop such as 8 or 5.6
07-10-2012, 06:14 PM   #3
slip's Avatar
QuoteOriginally posted by pdl1945 Quote
pdl1945
also check in your menu to see if the option to allow a F stop ring is set to "allowed"
thanks
randy
07-10-2012, 08:28 PM   #4
Not a Number's Avatar
If the F- - is flashing the menu option Aperture Ring is not set to permitted. It should be set to "permitted".
What lens are you using?
"A" lenses should be set to "A" - in manual mode you should see the meter bar. Adjust shutter speed and f stop via front and back dials, respectively.
Non-"A" lenses or not set on "A": stop-down metering: menu options - aperture ring - permitted, preview method - optical preview, Green button in TAv & M - TV Shift.
To use stop-down metering - set the f-stop you want on the aperture ring. Pressing the green button stops down, meters and sets the shutter speed. Or push the preview lever. This stops down the lens and turns on the bar meter. Set your aperture with the ring and the shutter speed with the front dial and "needle-match" the exposure. With screw-mount lenses it's best to focus and compose with the lens wide open before metering.
focus, k-10, lens, pentax help, shutter
AF vs manual lens rajchat Troubleshooting and Beginner Help 25 02-24-2014 09:48 AM
Linear Polarizer in Manual with manual lens Den Photographic Technique 8 12-19-2012 11:10 PM
K-x with Manual lens in Av MK-x Troubleshooting and Beginner Help 16 03-03-2012 03:55 PM
Tricking Kx into thinking manual lens is A-lens ChopperCharles Pentax SLR Lens Discussion 4 06-07-2011 07:40 PM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
All times are GMT -7. The time now is 08:30 PM. | See also: NikonForums.com, part of our network of photo forums!
