07-14-2012, 06:31 PM   #1
SD card Problem
I have a new SD card. Put it in the camera (K 2000) and formatted it. Took some Pictures and was fine. Deleted those pictures. Went to the Columbia Gorge to the Kiteboarding for Cancer event. I took tons of pictures. Got home and wanted to load on computer. Went to load and it says no pictures. Tried to open card and says no pictures. When I go into the part that says "computer" it shows my sd card and shows that there are pictures on the card taking up almost 1G of space. I can't bring the pictures up even though I know they are there.
Thought I should add, tried on my husbands computer too. Shows there should be pictures on it but won't show them. As I was taking the pictures they showed up on the camera screen. Now they won't show on the camera either.
Any help appreciated. Pixme
07-14-2012, 06:34 PM   #2
LeDave's Avatar
Is your SD card on lock?
07-14-2012, 06:54 PM   #3
Docrwm's Avatar
I've used SanDisk's RescuePRO software to recover lost files from an SD card, it worked when Norton and other PC programs couldn't help. I think it can still be downloaded from their site.
07-14-2012, 06:56 PM   #4
jatrax's Avatar
First, don't panic. There are programs that will recover pictures from SD cards quite easily, assuming that you have a problem. Recuva is one I have used myself and it found an entire days shooting and brought it back.
However, make sure you have a problem first! Stop and think everything through, don't rush into anything that might cause more harm.
What software are you using to 'load' the pictures?
What computer (mac or PC)?
Can you copy the files manually?
Do the pictures show if you put the card in the camera?
07-14-2012, 07:49 PM   #5
davidreilly3207's Avatar
Definitely download and use Recuva. IMPORTANT! Make sure you recover the files to anywhere but the sd card.
07-15-2012, 07:30 AM   #6
No it's not locked.
I'll try the suggestions. Thanks
07-15-2012, 11:40 AM   #7
Was this a larger SD card than you have used in the PC before? There are several SD specs, and if it's an older PC it may well not support SDHC or especially SDXC. I once traveled with PC with SD slot and while there got a new SDHC card. It worked fine in the camera, but that PC would never read it, while a newer PC had no problems.
07-15-2012, 11:47 AM   #8
If it wasn't locked, lock it now since it appears to be corrupted and you don't want any processes to be able to write to it until you've done your recovery (which is a "read-only" process).
07-15-2012, 09:42 PM   #9
sterretje's Avatar
How did you delete? Using the PC? In which case the 1GB might well be in the recycle bin. Or using the camera?
As said, use some recovery software to see what you can get back. I've used photorec with success when a P&S all-of-a-sudden told me that there were no pictures on a card after 3 days shooting.
camera, card, computer, load, pentax help, pictures, sd, sd card
Use of SD card that once had a problem sholtzma Troubleshooting and Beginner Help 20 06-22-2012 08:20 AM
SD card problem 2 demonbear247 Troubleshooting and Beginner Help 13 04-27-2011 05:06 AM
SD card problem Rupert Troubleshooting and Beginner Help 10 04-12-2011 06:55 PM
Memory Card Problem Conan Maol Troubleshooting and Beginner Help 7 02-20-2011 10:20 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
All times are GMT -7. The time now is 01:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
