Yes, if you have better quality lights (I have the Einsteins myself) with consistent color temperature, you should be able to directly set the K20 to match the color temperature (e.g. 5600K) of the lights. This is assuming most of your light is coming from them - not being mixed with ambient or other light sources. Otherwise, with mixed lighting, an Expo Disc is an ideal solution.
The advantage of the Expo Disc is you're measuring the actual light falling on the subject, so all the variables of mixed lighting are automatically taken into account.
