I'm just looking for some advice for a sunrise shot. I hope I’ve found the right section for this post.
The picture I have in mind looks something like this:
- main subject is the rising sun - should take up a HUGE proportion of the picture – as big as possible
- silhouette shots of a couple (actually of me and my wife!), either walking along the beach or one at either side of the sun posing. They should be recognisable in shape but comparatively small when compared to the sun
- it’ll go onto a 100cm x 75cm canvas, in landscape orientation, so I guess we need enough resolution for printing at this size.
To do this, I realise I need a VERY long lens plus cropping in PP. I have never worked with anything longer than 135mm. I’ve got a K-5.
- Any recommendation on what lens I can get?
- I can't justify spending a lot at this stage. I'm comfortable with using legacy lenses. I prefer K mount but M42 is fine too.
- I do own a tripod that is rated at 3kg, so I guess that limits the size/weight of the lens
- What’s the difference between a mirror lens and a normal lens? I like the compactness of a mirror lens prime, but at the same time I also like the flexibility afforded by a zoom
- Working distance
- Presumably when working with such a long lens, I'll need a HUGE working distance between the camera and the couple? What kind of working distance would I be looking at? As mentioned, I've never worked with a very long lens before. In this case, I guess I’ll have to use the camera’s timer and run very fast into position!
Any other piece of advice when doing this type of shoot?
Much appreciated in advance.
